Apparent Z-Banding Driving Me Crazy
mikehill85
Post by mikehill85 » Sat Jul 28, 2018 2:51 pm
Is this amount of banding normal? It appears on all my parts and has ever since I got my machine. I even noticed that it is present on the 3d printed parts for the machine itself.
It is really tough to photograph and it only really visible if there is a light source shining down on my parts from above. I am try to decide if I want to replace my Z lead screws or not. I'm not convinced it would help.
P.S. I have no idea why this damn window shows so many copies of the same image. Yet another flaw with Lulzbot/Alephobjects.
Orias
Re: Apparent Z-Banding Driving Me Crazy
Post by Orias » Sun Aug 05, 2018 3:48 pm
Reach out to the support team, you may want to take a few more images if you can: LulzBot.com/Support.
RCBrust
Post by RCBrust » Fri Aug 10, 2018 1:16 pm
I get the exact same thing. If you get anywhere with this issue, please let us know.
Randy
mikehill85
Post by mikehill85 » Fri Aug 10, 2018 6:51 pm
Some better pictures, for you reference.
mikehill85
Post by mikehill85 » Fri Aug 10, 2018 6:54 pm
Randy
Thanks for the response Randy. I'm thinking it is a bent Z-axis screw. I'll be sure to let you know if I ever get this resolved. Quite honestly, the reason I got the Lulzbot mini was so that I could have a printer that just worked and produced high quality prints. My 1st printer was a heavily modded Da Vinci. Currently, this print quality isn't any better than that of my $350 printer, probably worse in all honesty. I'm seriously considering dropping my 3d printer hobby. I can't tell you how frustrated I've been with this. I tried upgrading the firmware, turning the leadscrews so that the software didn't have to compensate as much, tightening belts, looking for loose bolts/screws, nothing has helped and I can't even stand to look at the prints my machine produces, the "quality" is complete garbage.
I had read in another post in this forum that there is a design flaw in the mini that causes, Z-wobble. Apparently there is a design flaw in the mini and most Taz printers. The axis is over-constrained by the bearings at the top and bottom of the printer Z-screws, as well as the two metal rods which also guide the Z-axis up and down.
viewtopic.php?t=2716
mikehill85
Post by mikehill85 » Sat Aug 11, 2018 10:04 am
Turns out the original 3d printed parts that are part of my machine also show the same banding (example below). I wish Alephobjects would just admit this is a design flaw, refund my money and stop wasting my time.
Keebie81
Post by Keebie81 » Sat Aug 11, 2018 3:37 pm
Randy
You could take the top off and remove the bearings. Thats what I did.
mikehill85
Post by mikehill85 » Sat Aug 11, 2018 3:41 pm
Randy
Which bearing did you remove? Both the top and bottom of each of the two Zs? Any pics of surface quality you can share?
It's pretty hilarious, I asked support about the banding on their own 3d printed parts from the factory and they just said that mine is worse...Personally, I think theirs is probably worse (they are likely printing at higher speeds so it is to be expected). I asked them to tell me if this is a know design flaw which can be resolved but they kept on suggesting silly possible fixes which clearly couldn't be causing the banding. One was the hobbed gear...yeah...I'm sure it's a feed rate issue that just happens to occur at the exact same pitch as the z-axis screw.
kcchen_00
Post by kcchen_00 » Sun Aug 12, 2018 1:59 pm
This will be happen with any printer with lead screws... unless heavily modified. Its the nature of the screw.
Try a sixteenth to eight turn of one lead screw (either right or left), not both screws. The idea is to get the screw contact point in the middle of the pitch opposite to the other lead screw. This would create a more consistent contact... no wobble due to the screws in phase. Anyway this is highly "trial and error"... YMMV
mikehill85
Post by mikehill85 » Mon Aug 13, 2018 5:51 pm
I've tried that before, it doesn't do anything. Also, I have no idea of the mechanism by which that is meant to work, given that the printer is trying to adjust for the bed not being perfectly level. It will be adjusting the different Z-axis screws by different amounts and end up at different positions along the Z-axis screws in different regions of the bed, in any case. Perhaps if your bed is relatively level to start with it may appear to help in a small area of the bed where there are basically no adjustments made.
