Taz 6 Pausing During Print Error Message Log
Have questions? Want advice?
ajusay74
Post by ajusay74 » Thu Sep 27, 2018 9:28 pm
Good evening,
What causing this error? Thank you.
< [20:07:07] Error:checksum mismatch, Last Line: 143543
< [20:07:07] USBPrinterOutputDevice: Resending from: 143544
< [20:07:07] ok N143543 P4 B4
< [20:07:07] Error:Line Number is not Last Line Number+1, Last Line: 143543
Galadriel
Re: Taz 6 Pausing During Print Error Message Log
Post by Galadriel » Fri Sep 28, 2018 6:42 am
More often than not that will be an issue with the base file that is causing it to slice with some oddities in the GCode. Basically the error is telling you that the next line of code it is supposed to be performing isn't in sequential order with the last (1, 2, 4 instead of 1, 2, 3). When it sees this it has to take a second and resend from the correct next code line. Could you post the model you are trying to print as an stl? I would like to look it over for potential causes of your trouble.
ajusay74
Post by ajusay74 » Fri Sep 28, 2018 10:06 am
Sure.
Facehugger.stl
(6.33 MiB) Downloaded 21 times
ajusay74
Post by ajusay74 » Fri Sep 28, 2018 1:10 pm
I've tested it both in Cura and Octoprint. I may have to do with some lag between communications. But Octoprint failed it and closed its connection.
Galadriel
Post by Galadriel » Fri Sep 28, 2018 2:19 pm
Thanks for posting your file! I used a software called Blender to scan it for errors that could potentially cause issues with printing and found quite a few. I am including a screenshot of the readout in case you are curious.
ajusay74
Post by ajusay74 » Fri Sep 28, 2018 2:56 pm
Thank you.
