Many print issues with moarstruder
cekuhnen
Re: Many print issues with moarstruder
Post by cekuhnen » Mon Nov 12, 2018 12:19 pm
My z-offset is at -1.2 but I can play with this setting more.
I remove before doing a new print any filament leftover.
We have another moarstruder at work and I will test the model there today to see if it is the model or the printer I bought refurbished.
Any other suggestion? Estep?
Galadriel
Post by Galadriel » Mon Nov 12, 2018 12:59 pm
I would start with those adjustments and see how things go before jumping into looking for other potential causes. In answer to your question I don't think this will relate to your E-Steps because your E-Steps control the overall extrusion of the toolhead and if this was off I would expect to see poor surface quality across the board not just on specific areas of prints. I will keep an eye out for updates once you have tried out a different MOARStruder!
cekuhnen
Post by cekuhnen » Tue Nov 13, 2018 9:29 pm
Here some more tests with Z-seam alignment
Fast print:
Sharpest
From all modes best still exhibiting a lot flaws such as lines not building upon each other correctly.
Shortest
this is probably the worst print ever with even thick gabs and some of the hexagon like vertical corners are rounded
one can also see that from the front the lines are aligned but on the opposite side the lines are off like along the y axis there is an increasing offset
Random
pretty bad result
This is a standard print speed
issues are present such as horizontal lines
it seems the printer still has trouble with printing each layer correctly where it should showing some small horizontal stepping issues - also here start end artifacts are still present
cekuhnen
Post by cekuhnen » Wed Nov 14, 2018 7:09 am
for the vase mode also CURA shows a layer issue that is visible in the prints too
I attached the raw cad files too
Archive.zip
(52.28 KiB) Downloaded 21 times
