pass lines and inconsistent layer levels
warped65
Post by warped65 » Sat Nov 03, 2018 8:43 pm
All,
I have been doing some prints with large flat panels on them, and always get some inconsistent levels where the surface has a hole or boss, and always get pass lines showing through. This is a Taz 6 using cura. Happens with ABS as well as PLA. These show up on sublayers too, which show through the final layer, making for a pretty sloppy looking surface.
For the pass lines, Is there a z-hop setting i am missing or something?
For the levels/layers, is there something i can try for layer height, or line thickness? Currently using a .5 nozzle. Have switche to a SS micor swiss nozzle, but the issue has always been there.
Thanks all,
-w
warped65
Re: pass lines and inconsistent layer levels
Post by warped65 » Sun Nov 04, 2018 10:32 am
Looks like the pic didn't come through, not sure what i'm doing wrong. Anyway, I'll try again. Pass lines are circled in blue, levels are circled in red.
kcchen_00
Post by kcchen_00 » Sun Nov 04, 2018 1:01 pm
Looks like over-extrusion. If you look at the pass-line, it shows the direction the nozzle is dragging across the piece. Try adjusting flowrate / multiplier by 2-5%.
Not sure about the layer level issue... it could also be related to over-extrusion.
kmanley57
Post by kmanley57 » Sun Nov 04, 2018 2:14 pm
Check out Z hop over printed parts in the travel section, but it will add a lot to the printing time. <- pass lines
warped65
Post by warped65 » Sun Nov 04, 2018 8:01 pm
Well, I can't tell if this was an improvement. Slowed the flow down to 95% partway through this print. I think the skins are a little smoother, but still seeing the jacked up patterns near the holes. I added a thin layer at the top just to avoid having the top layer interrupted by holes; it came out well, but i still want to improve. I'll try the z-hop setting next.
Thanks all,
-w
