Calibration Cube Taz6
OyarzoPablo
Post by OyarzoPablo » Mon Dec 03, 2018 10:02 am
Printed the calibration cube of Thingiverse: https://www.thingiverse.com/thing:1278865
From 20x20x20 mm
I got
X = 19.90
Y = 20.15
Z = 19.80
How do I proced to take these values closer to 20mm?
Keebie81
Re: Calibration Cube Taz6
Post by Keebie81 » Mon Dec 03, 2018 11:23 am
You adjust the steps/mm, but for that small variance I wouldnt worry. 3d printing isnt going to get an exact measurement due to material shrinkage and such.
OyarzoPablo
Post by OyarzoPablo » Mon Dec 03, 2018 11:54 am
In Cura or Setting on the Lulzbot?
I wanna get as close as I can, as I've seen many examples prints on the Lulzbot, Ender and Prusa.
zachah
Post by zachah » Mon Dec 03, 2018 3:54 pm
The easiest way is going to be with Cura. Use the scale option and un-check Uniform Scaling.
Then do some cross multiplying to find our desired X Y and Y percentages values. In this case with your measurements that comes out to:
X 100.50%
Y 99.26%
Z 101.01%
You'll take your desired value (20) and multiply that by 100 (for 100 percent), then you'll divide by your measured value(X,Y,Z) to get your adjusted percentage.
20*100=2000
2000/19.90=100.502512563
2000/20.15=99.255583127
2000/19.80=101.01010101
OyarzoPablo
Post by OyarzoPablo » Thu Dec 06, 2018 8:46 am
@zachah Worked great!
NOTE: if you do the test, be sure to rotate the model to match x and y axis. had problems for that.
1) Is there a way to make it permanent? on the setting for any imported STL?
2) What was the other not simpler way?
zachah
Post by zachah » Fri Dec 07, 2018 10:16 pm
I'm not aware of a way to have Cura automatically do this when importing an stl.
The less simple way would be to adjust your X,Y, and Z steps/mm. The issue with this is that it can affect your auto-leveling if adjusted too much since the corner positions are more or less hard coded into the firmware.
