dual extruder options?
Have questions? Want advice?
Huskerfan
Post by Huskerfan » Thu Feb 07, 2019 10:06 pm
I know this is Lulzbot's web site forum but are there any alternative dual extruder's that can fit the Taz 6 out there?
I had to return mine cause it kept getting plugged.
Thanks
ajrobertsx
Re: dual extruder options?
Post by ajrobertsx » Sun Feb 10, 2019 8:39 am
I think I fixed my dual extruder by adding a better 5v fan to cool the heat break. I used a fan with double the CFM than the stock one and so far have not gotten heat creep since the mod. Still experimenting on the fix.
kcchen_00
Post by kcchen_00 » Mon Feb 11, 2019 9:32 pm
Which dual extruder did you try?
Huskerfan
Post by Huskerfan » Mon Feb 18, 2019 10:47 pm
I tried the Lulzbot dual extruder but I thought maybe there was an off brand that still fits the Taz 6?
ajrobertsx, is there any soldering involved? I'm not experienced at that but I can unscrew some torx screws if I need to.
Gringotuerto
Post by Gringotuerto » Sat Mar 02, 2019 9:28 am
I have heard so many reviews complaining of inadequate cooling and jamming. What fan did you buy?
Also, I noticed there was a service bulletin where some v3 toolheads had a thermistor that was intermittently connecting due to "under-crimped" connector, leading to overheating. Are you sure the problem wasn't due to that? A faulty connection is usually pure open circuit, which on a thermistor would show very low temperature, not even in the ballpark of the actual. So I doubt this issue would lead to any subtle problem. But I don't really know for sure.
kcchen_00
Post by kcchen_00 » Sat Mar 02, 2019 9:30 pm
The V3 extruder is better than the V2. Both have quirks.
