Very bad results, extruder rubbing layer and more..
Have questions? Want advice?
sk8er000
Post by sk8er000 » Sat Feb 09, 2019 10:53 am
Hello,
I've finally received my taz 5 and after assembling and leveling the bed (leveled with a digital dial indicator and it's leveled +/- 0.01 mm) I can't have a single good print.
I'm using Hatchbox 3.00mm PLA (bed temperature 55/60 C, extruder temperature 160/200 C) and I sliced mainly with lulzbot cura with default profiles, but I've tried with simplify 3D and Slic3r too.
All the results are quite horrible (even with a low expectation) but I can't understand why they are so bad. I can't believe that those are the average Taz 5 results.
My main issues are:
1) a very bad first layer
2) the rubbing of the extruder on the previous layer.
3) a popping sound from the extruder
I've run a lot of times the bed leveling print and looking at that print I think there is a right distance between the bed and the extruder.
here are some photos of my leveling results and my print errors:
https://drive.google.com/open?id=1-0-uD ... 4BkDKU2ahA
thank you in advance for any help :)
dysan
Re: Very bad results, extruder rubbing layer and more..
Post by dysan » Sat Feb 09, 2019 2:47 pm
That sounds like over extrusion to me. Have you calibrated your esteps and then extrusion multiplier for the filament you are using? When I print hatchbox pla on my ender 3 I print at 215c temps and my extrusion multiplier is around .95 if I remember correctly but it will be different depending on nozzle size.
This should give you a general idea for estep calibration
https://www.matterhackers.com/articles/ ... r-extruder
This is an overall calibration guide for the extruder
https://www.3dhubs.com/talk/t/howto-cal ... ament/5695
sk8er000
Post by sk8er000 » Sat Feb 09, 2019 3:27 pm
Thank you for your reply, I I'm using the standard Taz 5 extruder with 0.5 nozzle, 'll try to check the extruder calibration.
sk8er000
Post by sk8er000 » Tue Feb 12, 2019 5:08 pm
I've tried to calibrate the extruder a couple of time (can't figure out why one day is ok and the next one is 2mm/1.80mm different). After that, using a polimaker PLA I've achieved a pretty good result trying to print benchy:
https://drive.google.com/folderview?id= ... nZf_g7V2Ow
