Should I lube my Mini?
mdivancic
Post by mdivancic » Sun Mar 10, 2019 8:07 pm
What, if anything, should be lubed on my Mini and what should I use for lube?
Regards,
Mike
Regards,
Mike
mdivancic
Re: Should I lube my Mini?
Post by mdivancic » Fri Mar 15, 2019 10:10 am
Perfect, thank you.
Regards,
Mike
Regards,
Mike
IDEngineer
Post by IDEngineer » Fri Mar 22, 2019 9:34 am
Those bearings may be intended as self lubricating but unless you keep them scrupulously clean they will get contaminated and, ultimately, noisy. That seems to be a one-way road, too. The stainless shafts on our Mini apparently got some dust on them and despite repeated cleanings, they now "groan" when the position and speed are just right. I suspect some dust/whatever got into the bearings, and no amount of shaft cleaning is getting it back out.
fastrobplus
Post by fastrobplus » Fri Mar 22, 2019 1:49 pm
Interesting. Both my lulzbots will make sea lion-type sounds under just the right conditions.
