Recommended method for changing filament mid print?
cougarprinting
Post by cougarprinting » Tue May 21, 2019 6:30 pm
I've read a few posts but they were all a bit old.
Can I change filament mid print using Cura or do I need to use a different software? What's the best way to do it right now?
b-morgan
Re: Recommended method for changing filament mid print?
Post by b-morgan » Wed May 22, 2019 10:35 am
Yes, you can change the filament mid print using Cura. This is accomplished by using a PostProcessing plugin script. These scripts can be accessed from the Extensions menu, Post Processing, Modify G-Code. These scripts are located at:
C:\Program Files (x86)\cura-lulzbot 3.6\plugins\PostProcessingPlugin\scripts
CuraLE contains a ColorChange script which should work. It uses the M600 G-Code command.
Alternatively, you could use the script I (and others) have modified, PauseAtHeightorLayer4.py which I have attached (in a .zip). Place the .py file in the above folder and (re)start CuraLE.
PauseAtHeightorLayer4.zip
(6.57 KiB) Downloaded 30 times
defuzz
Post by defuzz » Fri Jun 07, 2019 12:34 am
I tried awhile ago to get filament changes working with the existing plugins and ended up writing my own barebones plugin script for the PostProcessing plugin.
Tested on my Mini 1 with Lulzbot Cura.
https://github.com/aerickson/SimplePause
