Taz 2 evolved to 4
2con
Taz 2 evolved to 4
Post by 2con » Mon Jun 23, 2014 11:42 am
Can you guys send me in the right direction as to where I can purchase all the parts to upgrade my taz 2 into a taz 4 (mostly heated bed upgrade) as well as a bill of materials (parts to print/STL files to download via links) for the various changes made to the Z-axis hysteria. I want to do it all and make sure i'm not missing anything. I realize i cant upgrade my rambo holster, but that's ok.
Thanks a lot,
2Con
Taz 2 since crowdfunding 2013
-complete upgrade to Taz 6, swing-arm auto leveling, anti-z wobble installed, hardened steel rods with all linear bearings, vibration dampers, auto cleaning, hexagonal noz upgrade
To do:
-Cable carriers
piercet
Contact:
Re: Taz 2 evolved to 4
Post by piercet » Mon Jun 23, 2014 5:34 pm
Parts to make a Taz 3 into a Taz 4 (should be applicable for a Taz 2):
Parts to buy from Mitsumi:
Two Leadscrews - Misumi Part # MTSBRK12-420-F7-R8-T9-Q8-S20-E5-FE0-FW7-FY1
Two Lead Screw Nuts - Misumi Part # MTSRR12
Two Couplers - Misumi Part # GSASL16-5-5
Four 608zz Bearings - Two are for the upper bearings, Two for lower bearings.
Printed parts (required):
http://download.lulzbot.com/TAZ/4.0/pro ... tor_mount/
http://download.lulzbot.com/TAZ/4.0/pro ... nut_mount/
http://download.lulzbot.com/TAZ/4.0/pro ... top_drive/
Printed parts (optional frame enhancements)
http://download.lulzbot.com/TAZ/4.0/pro ... t_chassis/
http://download.lulzbot.com/TAZ/4.0/pro ... unt_table/
The LCD modules are available in the lulzbot store if the 2 didn't have them. I can't rememeber if it did or not. The 24v electronics you are on your own for.
2con
Post by 2con » Tue Jun 24, 2014 10:12 am
Thank you so much! this saves me a lot of time searching and questioning!
How come lulzbot does not sell a 24V Replacement bed? Where would I go about finding one potentially, or can I just "replace" the power supply to my current bed?
To do:
-Cable carriers
piercet
Contact:
Post by piercet » Tue Jun 24, 2014 11:32 am
You're welcome!
I dunno why they don't sell those, they probably don't have excess beyond what they need for their own production at this point, but thats a guess.
2con
Post by 2con » Tue Jun 24, 2014 11:52 am
Another thread suggests CPSX16-5-5 is a suitable replacement for GSASL16-5-5 but was not confirmed. Can you confirm that CPX16-5-5 couplers will work in place of the GSASL16-5-5?
Here are some links to purchase on Misumi for anybody else asking the same question as I am:
http://us.misumi-ec.com/(USA site not the international one >.<)
Lead Screws: http://us.misumi-ec.com/vona2/detail/11 ... E0-FW7-FY1
Lead Screw Nuts:http://us.misumi-ec.com/vona2/detail/11 ... de=MTSRR12
The GSASL16-5-5 are discontinued on Misumi but here is its brother?
Couplings: http://us.misumi-ec.com/vona2/detail/11 ... CPSX16-5-5
To do:
-Cable carriers
piercet
Contact:
Post by piercet » Tue Jun 24, 2014 2:53 pm
They should work fine. A 16-5-5 coupler is pretty much standard. I've only tried the other ones personally, but they shouldn't be a problem.
unxetas
Post by unxetas » Fri Jun 27, 2014 12:57 pm
Thanks for posting the question and thanks to the folks who replied! Sort of on the same topic, is there a list somewhere of the changes between the various TAZ releases? Just picked up a TAZ3, I've been searching for all the differences but this was really the first post I was able to find that listed some of the specific changes :)
Orias
Post by Orias » Fri Jun 27, 2014 1:42 pm
Here's A changelist for TAZ 3 > 4: http://devel.lulzbot.com/TAZ/Guava/prod ... _guava.odt The biggest change from your TAZ 3 to the current 4 is the Z axis drive system.
unxetas
Post by unxetas » Fri Jun 27, 2014 5:50 pm
Thanks Orias :)
unxetas
Post by unxetas » Sat Jun 28, 2014 11:09 am
I'm ordering some cheap sfu1204 ballscrews to try and adapt them to the TAZ3. One question though. Normally ballscrews are fixed at one end with two angular contact bearings. That's a bit overkill in this case, looking at the pictures, are the taz4 leadscrews fixed to the lower bearing at all? Looks like it just goes through a 608zz bearing, so what's keeping it in place axially?
