Your best bet would be to use the standard 0.35mm profiles as a base. Import them into your slicing engine then change the nozzle diameter variable to 0.5mm and cut a test model to see what you’ll need to tweak from there. You can probably go faster without too much fiddling, but take it a variable at a time.
