I notice that auto level was screwing my first layer in corner 1 and 3 which coincides with prop point 1&3. I turned off auto level and my bed was with in .1 mm across x and .2 ish mm across y. So I looked at the probing points results you can see it below. I also found out that 3 out of the 4 points are not good in my opinion. Points 1,3 & 4 are too far in y direction as you see in the picture. I would like change the Y value for points 1&4 to 156.000. Point 3 I would like to change the y value to -10 if possible. it seem that my bed is not squared with chase. I would like all four point to be on the inside corner of glassl like prop point 2 (see picture). I know that i need to change
#define LEFT_PROBE_BED_POSITION (-3 + 0)
#define RIGHT_PROBE_BED_POSITION 161
#define FRONT_PROBE_BED_POSITION (-7 + 0)
#define BACK_PROBE_BED_POSITION 161
First I don’t want to lose my current configuration.
Does the Bed Height vs. Bed Topology look right look correct?
How can I compile a new firmware when I can’t download the software development from lulzbot?
How can I fix my bed to get it squared?
Can I change the position of one prop point without effecting the others?
Prop point 1
Prop point 2
prop point 3
prop point 4
Recv: G29 Auto Bed Leveling
Recv: Bed X: -3.000 Y: 161.000 Z: -3.818
Recv: Bed X: -3.000 Y: -7.000 Z: -3.071
Recv: Bed X: 161.000 Y: -7.000 Z: -3.528
Recv: Bed X: 161.000 Y: 161.000 Z: -3.014
Recv: 4th probe point, distance from plane: 1.26
Recv:
Recv: Eqn coefficients: a: 0.00106098 b: -0.00069494 d: -3.38799452
Recv: Mean of sampled points: -3.35768747
Recv:
Recv: Bed Height Topography:
Recv: ±-- BACK --+
Recv: | |
Recv: L | (+) | R
Recv: E | | I
Recv: F | (-) N (+) | G
Recv: T | | H
Recv: | (-) | T
Recv: | |
Recv: O-- FRONT --+
Recv: (0,0)
Recv: -0.46069 +0.34394
Recv: +0.28669 -0.16994
Recv:
Recv:
Recv: Corrected Bed Height vs. Bed Topology:
Recv: +0.00000 +0.63062
Recv: +0.63063 +0.00000
Recv:
Recv: Bed Level Correction Matrix:
Recv: +1.000000 +0.000000 +0.001061
Recv: +0.000001 +1.000000 -0.000695
Recv: -0.001061 +0.000695 +0.999999
Recv: X:161.00 Y:161.00 Z:6.34 E:0.00 Count X:16180 Y:16181 Z:10447
