Anyone else printing Carbon Fiber Nylon? What are your print settings?
I have a TAZ 5 I just got my first roll of 3DXTech’s CarbonX, which is a carbon-fber-nylon similar to NylonX. I also do have a hardened steel 0.6mm nozzle that I’m about to install, but I wanted to do a test print, so here is my print with the original 0.5mm brass nozzle. I cobbled together a Cura printing profile from a Carbon-PLA profile and a Nylon profile.
Print is not perfect, but it looks pretty good… a few clumps, I’ve never really tried to custom make a profile before, any advice appreciated. Cura Profile include beneath the photos.
There is some residual gluestick on the bed,which I heated to 110º (80º-100º is recommended) adhesion was fine.
260º print temp.
I’m printing at 50mm/s no problem.
East egg STL file: https://www.thingiverse.com/thing:2829553
[profile]
layer_height = 0.4
wall_thickness = 1.2
retraction_enable = True
solid_layer_thickness = 1.14
fill_density = 50
perimeter_before_infill = True
nozzle_size = 0.5
print_speed = 50
print_temperature = 260
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 110
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 2.88
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100.0
retraction_speed = 50
retraction_amount = 3
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.01
retraction_hop = 0.1
bottom_thickness = 0.38
layer0_width_factor = 125
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 180
bottom_layer_speed = 15
infill_speed = 50
solidarea_speed = 40
inset0_speed = 40
insetx_speed = 45
cool_min_layer_time = 20
fan_enabled = False
skirt_line_count = 1
skirt_gap = 6
skirt_minimal_length = 0
fan_full_height = 0.5
fan_speed = 40
fan_speed_max = 50
cool_min_feedrate = 7
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Lines
support_angle = 45
support_fill_rate = 30
support_xy_distance = 1.5
support_z_distance = 0.2
spiralize = False
simple_mode = False
brim_line_count = 10
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.5
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
simplemodesettings =
simplemodeprofile = 2_normal
simplemodematerial =
simplemodematerialtype = Beginner
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 R{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 R{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed};move the platform down 15mm
G92 E0 ; zero the extruded length
G1 F200 E0 ; extrude 3mm of feed stock
G92 E0 ; zero the extruded length again
G1 F{travel_speed} ; set travel speed
M203 X192 Y208 Z3 ; speed limits
M117 Printing... ; send message to LCD
end.gcode = M400
M104 S0 ; hotend off
M140 S0 ; heated bed heater off (if you have it)
M107 ; fans off
G91 ; relative positioning
G1 E-1 F300 ; retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F3000 ; move Z up a bit and retract filament even more
G90 ; absolute positioning
G1 X0 Y250 ; move to cooling position
M84 ; steppers off
M117 TAZ Ready.
;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
T1 ;Switch to the 2nd extruder
G92 E0 ;zero the extruded length
G1 F200 E10 ;extrude 10mm of feed stock
G92 E0 ;zero the extruded length again
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 2nd extruder
G1 F{travel_speed}
M117 Printing...
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
T2 ;Switch to the 3th extruder
G1 F{travel_speed}
M117 Printing...
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
