Wonder if with new tool heads, Lulzbot jumps on linear advance band wagon
Well, you can use mine as a start? Mind that I use bleeding-edge Slic3r builds from https://dl.slic3r.org/dev/. Be careful that wipe code could be incompatible with Marlin 1.1.5, I stopped using wipe before print and clean it manually before it descends for probe. And I switched to FWRetract, so “Mini no wipe” printer profile lacks slicer generated retracts settings!
Slic3r_config_bundle.ini (21.7 KB)
Thank you! I’m busy playing with my new Aerostruder, but adding these profiles and playing with Slic3R just made #2 on my list.
Really appreciate you taking time to post them.
