Just wondering if someone can tell me the power output for this heater…
I’m pretty sure this is a resistive heater so the power output in heat should be about the same as the electrical power input.
Thanks but power is measured in watts which can’t be calculated without amps. Amps is drawn by a device, not pushed by the source.
I ended up ordering a 500 watt keenovo heater anyways since nobody could answer this and I couldn’t find an answer in any of their docs and I needed a new heater.
