Hi there, I was thinking about replacing the current fans in my Mini with 12V computer case fans. I realize that the 80mm and 40mm fans in the mini run at 24V, but if the fans tolerate 24V, will I risk damaging the electronics board by using 12V fans?
I have found 12 volt fans do not like to be supplied with a 24 volt PWM. They tend to not turn at all, or make a LOT of noise from the pulses going through them. YMMV.
Plus I would worry they could catch fire while under operation and not be noticed soon enough.
Since the fan is an inductive load, I decided to add inline resistors to halve the voltage.
The fan is 12V, 0.05A, which works out to an impedance of 240. I put a 250 ohm inline resistor (1x100 ohm and 1x 150ohm) in the way and the fan is spinning at a reasonable speed now.
I’m curious though, can I just take off the inline resistors and run the cooling fan at 50%? If the fans are voltage controlled that should give 12V, right?
Edit: Teddy, since the fan is a load, the second half of your voltage divider will have an overall impedance much lower than 1k ohm.
It is more 24 volts then 0 volts with a 50% ON-OFF duty cycle rate. The average would be 12 volts with a ‘nice’ buzzzzzz from the PWM, as the fan tries to go really fast then stop spinning at some KHZ rate.
