.5 nozzle poor results
Been a while since I’ve printed PLA with a .5 nozzle. Filament is 2.85 3D-Fuel Pro PLA. Welcome any improvement suggestions.
Which layer resolution have you used in decimals of a mm as per settings not the nozzle itself
Thanks Tim
Layer Height is .25
Profile Used:
lulzbot_hibiscus_pla 50 percent[general]
version = 2
name = PLA 50 percent
definition = lulzbot_hibiscus
[metadata]
material = Pro_PLA_(3D-Fuel)_lulzbot_hibiscus
type = quality_changes
setting_version = 4
quality_type = standard
[values]
infill_sparse_density = 50
material_flow = 98
material_flow_layer_0 = 98
material_keep_part_removal_temperature = False
retraction_combing = all
skirt_line_count = 4
wall_thickness = 2
PK ! YÚŠ_Ÿ Ÿ $ base/lulzbot_hibiscus_pla 50 percent[general]
version = 2
name = Standard
[metadata]
type = quality
setting_version = 4
[values]
acceleration_roofing = 500
bottom_thickness = 1.25
brim_line_count = 10
carve_multiple_volumes = True
cool_fan_full_at_height = 0
cool_fan_full_layer = 5
cool_fan_speed_min = 100
cool_min_layer_time = 15
cool_min_layer_time_fan_speed_max = 0
cool_min_speed = 5
default_material_print_temperature = 215
expand_skins_expand_distance = 0
fill_outline_gaps = False
infill_before_walls = False
infill_pattern = lines
infill_sparse_density = 30
layer_0_z_overlap = 0.5
layer_height = 0.25
layer_height_0 = 0.35
layer_start_x = 141
layer_start_y = 141
line_width = 0.5
material_bed_temperature = 45
material_bed_temperature_layer_0 = 55
material_final_print_temperature = 210
material_initial_print_temperature = 210
material_part_removal_temperature = 35
material_print_temperature_layer_0 = 210
material_probe_temperature = 160
material_soften_temperature = 180
material_wipe_temperature = 170
prime_tower_size = 7.745966692414834
raft_airgap = 0.5
retract_at_layer_change = True
retraction_amount = 1.5
retraction_combing = off
retraction_count_max = 99
retraction_extrusion_window = 3
retraction_hop_enabled = False
retraction_min_travel = 3
retraction_speed = 15
skin_preshrink = 0
skirt_brim_minimal_length = 250
skirt_gap = 5
skirt_line_count = 2
speed_infill = 40
speed_layer_0 = 15
speed_print = 40
speed_slowdown_layers = 3
speed_support = 40
speed_support_interface = 40
speed_topbottom = 35
speed_travel = 170
speed_travel_layer_0 = 70
speed_wall = 35
speed_wall_0 = 35
speed_wall_x = 35
support_angle = 60
support_bottom_stair_step_height = 0.5
support_bottom_stair_step_width = 5
support_brim_enable = True
support_brim_width = 5
support_enable = False
support_infill_rate = 15
support_interface_density = 50
support_interface_enable = True
support_interface_pattern = lines
support_interface_skip_height = 0.25
support_join_distance = 3
support_offset = 0
support_use_towers = False
support_xy_distance = 0.5
support_xy_distance_overhang = 0.5
support_z_distance = 0.5
switch_extruder_prime_speed = 10
switch_extruder_retraction_amount = 20
switch_extruder_retraction_speeds = 10
top_bottom_thickness = 1.25
top_thickness = 1.25
travel_compensate_overlapping_walls_enabled = False
wall_thickness = 1
zig_zaggify_infill = True
PK  ! RŸz‹ ‹  lulzbot_hibiscus_pla 50 percentPK  ! YÚŠ_Ÿ Ÿ $ È base/lulzbot_hibiscus_pla 50 percentPK   Ÿ ©
Doesn’t look too bad, really. Maybe slightly overextruded, but with the Z offset just a touch high to compensate on the bottom layer?
OK Thanks
I will lower Z and set extrusion to 95%.
Also noticing that.3d-fuel pro likes 220-230.
That’s good to know I just bought a sidekick and got same results. I will use those settings as well.
Let me lend you a hand
did you dry your filament?
I can count the layers from across the room! Either you’re running a 2mm nozzle or there’s a misplaced decimal point somewhere.
I had the wrong head selected in Cura, Worked great from fusion 360.. finally talked with Lulzbot, they talked me through. AOK, now experimenting with PETG I Also built a cabinet, and so on. Used the upsidown cerial box idea with rollers and that works pretty good, now I don’t have to fool around ever time I start and stop for the day, I just push the 3mm media back in. Good to go, meter show about 12% I just put dryer pellets in a little bag I got with them, and toss them into the bottom between the rollers.
