Hey there,
Just got a mini, and installed the cuar software on a small laptop running Ubuntu 15.10. It failed to autodetect the serial port but after fiddling about with the machine settings and serial port managed to get it to work. I also ran
sudo usermod -a -G tty $USER
sudo usermod -a -G dialout $USER
sudo usermod -a -G serial $USER (got an error on this one)
The second print went wrong. I’m guessing it was a problem with cura as I found the software in a hung state, so I decided to install on my main Ubuntu 15.04 pc. Got everything set up but I keep getting the Error: Failed to autodetect serial port.
Did all the same things but still no luck.
After checking on the internet a bit, I ran cura as root and then it connected. Has anyone come across this? What am I missing to get it to connect without running it as root.?
Some more info:
ls -ld /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Feb 13 10:12 /dev/ttyACM0
Log:
_Changing monitoring state from ‘Offline’ to ‘Opening serial port’
Connecting to: /dev/serial/by-id/usb-UltiMachine__ultimachine.com__RAMBo_74034313938351C0D041-if00 with baudrate: 115200 (configured)
Unexpected error while connecting to serial port: /dev/serial/by-id/usb-UltiMachine__ultimachine.com__RAMBo_74034313938351C0D041-if00 SerialException: ‘could not open port /dev/serial/by-id/usb-UltiMachine__ultimachine.com__RAMBo_74034313938351C0D041-if00: [Errno 13] Permission denied: ‘/dev/serial/by-id/usb-UltiMachine__ultimachine.com__RAMBo_74034313938351C0D041-if00’’ @ machineCom.py:monitor:346
Found no ports to try for auto detection
Changing monitoring state from ‘Opening serial port’ to ‘Error: Failed to autodetect serial port.’
