Ever start a long print, and then scream when the filament jams, or you run out of filament … and wish you could have just PAUSED the print when the filament stops moving/extruding?
Andrew Tunell has you covered! ( This mod is for machines running Sailfish, but I don’t see why it wouldn’t work on the TAZ w/ RAMBO as long as you choose an appropriate pin to trigger the ‘pause’ function. This may require re-compiling the firmware )
I’m going to see if I can design a filament holder for his detector that can be bolted onto the TAZ 6.
