Is there a way t look at and change the x and y distances for the G29 probing sequence?
also is there a way to reset the printers main xy zero location?
Thanks
The coordinates used by G29 are set by the firmware. Since the firmware is open source Marlin, you can download and examine the source code. Just need to know what model printer and what version of the firmware.
The printer determines the axis zero locations by using end stops with G28. You can shift this position using M206.
What is the problem you are trying to solve?
Thanks for the response. Iām using a v3 dual Extruder on just E0. I was going to have just that nozzle do the touch off.
This is the section where the Bed Leveling stuff for a range of Lulzbot printers is configured in the Drunken Octopus fork of Marlin (I highly recommend Drunken Octopus as a starting point if youāre going to work on customizing your firmware.)
Makes sense, thanks!
Hello,
My problem is the printer (TAZ 6) doesnāt center my model on the build plate. This wasnāt a problem 7 months ago- even old gcodes place the part in the center. I tried to reload an older version (on the computer) that I used before but that didnāt change anything (this is where I"m at currently).
Do I need to upgrade the version on the printer (1.1.5.71)?
Thank you.
The version of CuraLE and the firmware loaded on the printer should be compatible (i.e. use CuraLE to update the firmware and it will install a compatible version).
You can downgrade CuraLE if you wish but let it install a downgraded version of the firmware.
I should mention that the printer is not connected to the network so we have to hand-deliver the files to the printer.
Logistics aside, you are slicing files somewhere with an unidentified slicer. You are printing the resulting gcode delivered by an unidentified method on a TAZ 6 with a very old version of firmware (if 1.1.5.71 is the firmware version).
Either you adjust the printer settings on the slicer to match the current firmware or you find a way to get a system with CuraLE close enough to the printer to update its firmware to a more recent version.
Without more details (like version numbers) we canāt do much to solve your ācenter of the build plateā issue. Slice a simple object like a 3x3x3mm cube and post the gcode here.
My TAZ 6 is connected to an RPi 3B running OctoPi / OctoPrint.
There is a plugin for OctoPrint that allows firmware updating.
If you can actually find a Pi these days, thatās the way to go. I have many Pi3bās running Octoprint and Obico (formerly Spaghetti Detective). Be aware that youāll want to be conservative in your print speeds since the printerās control board can only push so much data out. Those USB UARTS are pretty slow and Iāve seen defects show up in prints if you push past 50mm/s
This might help finding a Raspberry Pi
Hereās the code file:
;Generated by Cura LulzBot Edition GCodeWriter Version: 3.6.23
;FLAVOR:Marlin
;TIME:70
;Filament used: 0.0139424m
;Layer height: 0.14
;Generated with Cura_SteamEngine 3.6.23
M82 ;absolute extrusion mode
;This G-Code has been generated specifically for the LulzBot TAZ 6 with standard extruder
M73 P0 ; clear GLCD progress bar
M75 ; start GLCD timer
G26 ; clear potential āprobe failā condition
M107 ; disable fans
M420 S0 ; disable previous leveling matrix
G90 ; absolute positioning
M140 S60.0 ; start bed heating up
M109 R140 ; soften filament before homing Z
G28 ; Home all axis
G1 E-30 F100 ; retract filament
M109 R140 ; wait for extruder to reach wiping temp
G1 X-15 Y100 F3000 ; move above wiper pad
G1 Z1 ; push nozzle into wiper
G1 X-17 Y95 F1000 ; slow wipe
G1 X-17 Y90 F1000 ; slow wipe
G1 X-17 Y85 F1000 ; slow wipe
G1 X-15 Y90 F1000 ; slow wipe
G1 X-17 Y80 F1000 ; slow wipe
G1 X-15 Y95 F1000 ; slow wipe
G1 X-17 Y75 F2000 ; fast wipe
G1 X-15 Y65 F2000 ; fast wipe
G1 X-17 Y70 F2000 ; fast wipe
G1 X-15 Y60 F2000 ; fast wipe
G1 X-17 Y55 F2000 ; fast wipe
G1 X-15 Y50 F2000 ; fast wipe
G1 X-17 Y40 F2000 ; fast wipe
G1 X-15 Y45 F2000 ; fast wipe
G1 X-17 Y35 F2000 ; fast wipe
G1 X-15 Y40 F2000 ; fast wipe
G1 X-15 Y30 Z2 F2000 ; fast wipe
G1 X-15 Y25 F2000 ; fast wipe
G1 X-17 Y30 F2000 ; fast wipe
G1 X-15 Y25 Z1.5 F1000 ; slow wipe
G1 X-17 Y23 F1000 ; slow wipe
G1 Z10 ; raise extruder
M109 R140 ; wait for extruder to reach probe temp
G1 X-9 Y-9 ; move above first probe point
M204 S100 ; set probing acceleration
G29 ; start auto-leveling sequence
M420 S1 ; activate bed level matrix
M425 Z ; use measured Z backlash for compensation
M425 Z F0 ; turn off measured Z backlash compensation. (if activated in the quality settings, this command will automatically be ignored)
M204 S500 ; restore standard acceleration
G1 X0 Y0 Z15 F5000 ; move up off last probe point
G4 S1 ; pause
M400 ; wait for moves to finish
M117 Heating⦠; progress indicator message on LCD
M109 R210 ; wait for extruder to reach printing temp
M190 R60.0 ; wait for bed to reach printing temp
G1 Z2 E0 F75 ; prime tiny bit of filament into the nozzle
M117 TAZ 6 Printing⦠; progress indicator message on LCD
M221 S100 T0
G92 E0
G1 F600 E-1.5
;LAYER_COUNT:20
;LAYER:0
M107
G0 F2625 X1.493 Y-6.24 Z0.425
;TYPE:SKIRT
G1 F600 E0
G1 F900 X2.199 Y-6.2 E0.02355
G1 X2.895 Y-6.08 E0.04708
G1 X3.574 Y-5.883 E0.07063
G1 X4.226 Y-5.61 E0.09418
G1 X4.843 Y-5.265 E0.11772
G1 X5.417 Y-4.853 E0.14126
G1 X5.941 Y-4.378 E0.16482
G1 X6.408 Y-3.848 E0.18835
G1 X6.812 Y-3.268 E0.21189
G1 X7.149 Y-2.646 E0.23546
G1 X7.412 Y-1.99 E0.259
G1 X7.6 Y-1.309 E0.28253
G1 X7.71 Y-.611 E0.30607
G1 X7.741 Y0.01 E0.32678
G1 X7.741 Y2.991 E0.42608
G1 X7.701 Y3.697 E0.44964
G1 X7.582 Y4.393 E0.47316
G1 X7.384 Y5.072 E0.49672
G1 X7.112 Y5.724 E0.52025
G1 X6.767 Y6.341 E0.5438
G1 X6.355 Y6.916 E0.56736
G1 X5.881 Y7.44 E0.59089
G1 X5.35 Y7.907 E0.61445
G1 X4.771 Y8.311 E0.63797
G1 X4.149 Y8.648 E0.66153
G1 X3.493 Y8.912 E0.68509
G1 X2.812 Y9.1 E0.70862
G1 X2.114 Y9.21 E0.73216
G1 X1.491 Y9.241 E0.75293
G1 X-1.491 Y9.241 E0.85227
G1 X-2.197 Y9.201 E0.87582
G1 X-2.893 Y9.082 E0.89934
G1 X-3.572 Y8.884 E0.9229
G1 X-4.224 Y8.612 E0.94643
G1 X-4.841 Y8.267 E0.96998
G1 X-5.416 Y7.855 E0.99354
G1 X-5.94 Y7.381 E1.01708
G1 X-6.407 Y6.85 E1.04064
G1 X-6.811 Y6.271 E1.06415
G1 X-7.148 Y5.649 E1.08772
G1 X-7.412 Y4.993 E1.11127
G1 X-7.6 Y4.312 E1.13481
G1 X-7.71 Y3.614 E1.15834
G1 X-7.741 Y2.991 E1.17912
G1 X-7.741 Y0.009 E1.27845
G1 X-7.701 Y-.697 E1.30201
G1 X-7.582 Y-1.393 E1.32553
G1 X-7.384 Y-2.072 E1.34909
G1 X-7.112 Y-2.724 E1.37262
G1 X-6.767 Y-3.341 E1.39617
G1 X-6.355 Y-3.916 E1.41973
G1 X-5.881 Y-4.44 E1.44327
G1 X-5.35 Y-4.907 E1.46682
G1 X-4.771 Y-5.311 E1.49034
G1 X-4.149 Y-5.648 E1.5139
G1 X-3.493 Y-5.912 E1.53746
G1 X-2.812 Y-6.1 E1.56099
G1 X-2.114 Y-6.21 E1.58453
G1 X-1.489 Y-6.241 E1.60537
G1 X1.493 Y-6.24 E1.7047
G0 F2625 X1.493 Y-5.74
G1 F900 X2.17 Y-5.7 E1.7273
G1 X2.837 Y-5.58 E1.74987
G1 X3.486 Y-5.383 E1.77246
G1 X4.106 Y-5.111 E1.79501
G1 X4.691 Y-4.767 E1.81762
G1 X5.231 Y-4.357 E1.84021
G1 X5.719 Y-3.887 E1.86277
G1 X6.148 Y-3.362 E1.88536
G1 X6.513 Y-2.791 E1.90793
G1 X6.808 Y-2.18 E1.93053
G1 X7.028 Y-1.539 E1.95311
G1 X7.172 Y-.877 E1.97567
G1 X7.241 Y0.01 E2.00531
G1 X7.241 Y2.991 E2.10461
G1 X7.201 Y3.668 E2.1272
G1 X7.082 Y4.335 E2.14977
G1 X6.885 Y4.984 E2.17236
G1 X6.613 Y5.605 E2.19494
G1 X6.269 Y6.189 E2.21752
G1 X5.86 Y6.73 E2.24011
G1 X5.389 Y7.218 E2.2627
G1 X4.865 Y7.647 E2.28526
G1 X4.293 Y8.012 E2.30786
G1 X3.683 Y8.307 E2.33043
G1 X3.042 Y8.528 E2.35302
G1 X2.38 Y8.672 E2.37559
G1 X1.491 Y8.741 E2.40529
G1 X-1.491 Y8.741 E2.50462
G1 X-2.168 Y8.701 E2.52721
G1 X-2.835 Y8.582 E2.54978
G1 X-3.484 Y8.385 E2.57237
G1 X-4.105 Y8.113 E2.59496
G1 X-4.689 Y7.769 E2.61753
G1 X-5.23 Y7.36 E2.64012
G1 X-5.718 Y6.889 E2.66272
G1 X-6.147 Y6.365 E2.68527
G1 X-6.512 Y5.793 E2.70788
G1 X-6.807 Y5.183 E2.73045
G1 X-7.028 Y4.542 E2.75303
G1 X-7.172 Y3.88 E2.7756
G1 X-7.241 Y2.991 E2.8053
G1 X-7.241 Y0.009 E2.90463
G1 X-7.201 Y-.668 E2.92722
G1 X-7.082 Y-1.335 E2.94979
G1 X-6.885 Y-1.984 E2.97238
G1 X-6.613 Y-2.605 E2.99497
G1 X-6.269 Y-3.189 E3.01754
G1 X-5.86 Y-3.73 E3.04014
G1 X-5.389 Y-4.218 E3.06273
G1 X-4.865 Y-4.647 E3.08529
G1 X-4.293 Y-5.012 E3.10789
G1 X-3.683 Y-5.307 E3.13046
G1 X-3.042 Y-5.528 E3.15304
G1 X-2.38 Y-5.672 E3.17561
G1 X-1.489 Y-5.741 E3.20538
G1 X1.493 Y-5.74 E3.30471
G0 F2625 X1.493 Y-5.24
G1 F900 X2.139 Y-5.2 E3.32627
G1 X2.776 Y-5.08 E3.34786
G1 X3.393 Y-4.883 E3.36944
G1 X3.981 Y-4.612 E3.391
G1 X4.531 Y-4.27 E3.41258
G1 X5.035 Y-3.863 E3.43416
G1 X5.485 Y-3.397 E3.45574
G1 X5.874 Y-2.879 E3.47731
G1 X6.197 Y-2.317 E3.49891
G1 X6.448 Y-1.72 E3.52048
G1 X6.623 Y-1.097 E3.54203
G1 X6.72 Y-.456 E3.56363
G1 X6.741 Y0.01 E3.57917
G1 X6.741 Y2.991 E3.67847
G1 X6.701 Y3.638 E3.70006
G1 X6.582 Y4.274 E3.72161
G1 X6.385 Y4.891 E3.74319
G1 X6.114 Y5.48 E3.76478
G1 X5.772 Y6.03 E3.78636
G1 X5.365 Y6.534 E3.80794
G1 X4.899 Y6.984 E3.82951
G1 X4.382 Y7.373 E3.85107
G1 X3.82 Y7.696 E3.87266
G1 X3.223 Y7.947 E3.89423
G1 X2.599 Y8.123 E3.91583
G1 X1.959 Y8.22 E3.93739
G1 X1.491 Y8.241 E3.95299
G1 X-1.491 Y8.241 E4.05233
G1 X-2.138 Y8.201 E4.07392
G1 X-2.774 Y8.082 E4.09547
G1 X-3.391 Y7.885 E4.11705
G1 X-3.98 Y7.614 E4.13864
G1 X-4.53 Y7.272 E4.16022
G1 X-5.034 Y6.865 E4.1818
G1 X-5.484 Y6.399 E4.20338
G1 X-5.873 Y5.882 E4.22493
G1 X-6.196 Y5.32 E4.24652
G1 X-6.447 Y4.723 E4.26809
G1 X-6.623 Y4.099 E4.28969
G1 X-6.72 Y3.459 E4.31125
G1 X-6.741 Y2.991 E4.32686
G1 X-6.741 Y0.009 E4.42619
G1 X-6.701 Y-.638 E4.44778
G1 X-6.582 Y-1.274 E4.46933
G1 X-6.385 Y-1.891 E4.49091
G1 X-6.114 Y-2.48 E4.5125
G1 X-5.772 Y-3.03 E4.53408
G1 X-5.365 Y-3.534 E4.55566
G1 X-4.899 Y-3.984 E4.57724
G1 X-4.382 Y-4.373 E4.59879
G1 X-3.82 Y-4.696 E4.62038
G1 X-3.223 Y-4.947 E4.64195
G1 X-2.599 Y-5.123 E4.66355
G1 X-1.959 Y-5.22 E4.68511
G1 X-1.489 Y-5.241 E4.70078
G1 X1.493 Y-5.24 E4.80011
G0 F2625 X1.493 Y-4.74
G1 F900 X2.107 Y-4.7 E4.82061
G1 X2.712 Y-4.58 E4.84115
G1 X3.296 Y-4.384 E4.86167
G1 X3.849 Y-4.113 E4.88219
G1 X4.363 Y-3.773 E4.90272
G1 X4.829 Y-3.37 E4.92324
G1 X5.238 Y-2.909 E4.94377
G1 X5.584 Y-2.4 E4.96427
G1 X5.862 Y-1.85 E4.9848
G1 X6.066 Y-1.268 E5.00534
G1 X6.193 Y-.665 E5.02587
G1 X6.241 Y0.01 E5.04841
G1 X6.241 Y2.991 E5.14771
G1 X6.201 Y3.606 E5.16824
G1 X6.082 Y4.21 E5.18874
G1 X5.885 Y4.794 E5.20927
G1 X5.615 Y5.348 E5.2298
G1 X5.275 Y5.862 E5.25033
G1 X4.872 Y6.328 E5.27085
G1 X4.412 Y6.737 E5.29135
G1 X3.902 Y7.084 E5.3119
G1 X3.352 Y7.361 E5.33242
G1 X2.771 Y7.565 E5.35293
G1 X2.168 Y7.693 E5.37346
G1 X1.491 Y7.741 E5.39607
G1 X-1.491 Y7.741 E5.4954
G1 X-2.106 Y7.701 E5.51593
G1 X-2.71 Y7.582 E5.53644
G1 X-3.294 Y7.385 E5.55697
G1 X-3.848 Y7.115 E5.57749
G1 X-4.362 Y6.775 E5.59802
G1 X-4.828 Y6.372 E5.61854
G1 X-5.237 Y5.912 E5.63905
G1 X-5.584 Y5.402 E5.6596
G1 X-5.861 Y4.852 E5.68011
G1 X-6.065 Y4.271 E5.70062
G1 X-6.193 Y3.668 E5.72115
G1 X-6.241 Y2.991 E5.74376
G1 X-6.241 Y0.009 E5.84309
G1 X-6.201 Y-.606 E5.86362
G1 X-6.082 Y-1.21 E5.88413
G1 X-5.885 Y-1.794 E5.90466
G1 X-5.615 Y-2.348 E5.92519
G1 X-5.275 Y-2.862 E5.94572
G1 X-4.872 Y-3.328 E5.96624
G1 X-4.412 Y-3.737 E5.98674
G1 X-3.902 Y-4.084 E6.00729
G1 X-3.352 Y-4.361 E6.0278
G1 X-2.771 Y-4.565 E6.04831
G1 X-2.168 Y-4.693 E6.06885
G1 X-1.489 Y-4.741 E6.09152
G1 X1.493 Y-4.74 E6.19085
G0 F2625 X1.492 Y-4.24
G1 F900 X2.074 Y-4.2 E6.21029
G1 X2.644 Y-4.081 E6.22968
G1 X3.193 Y-3.884 E6.24911
G1 X3.71 Y-3.615 E6.26852
G1 X4.185 Y-3.277 E6.28794
G1 X4.609 Y-2.878 E6.30734
G1 X4.975 Y-2.424 E6.32676
G1 X5.275 Y-1.925 E6.34616
G1 X5.504 Y-1.389 E6.36557
G1 X5.658 Y-.827 E6.38498
G1 X5.741 Y0.01 E6.413
G1 X5.741 Y2.991 E6.5123
G1 X5.701 Y3.572 E6.5317
G1 X5.582 Y4.143 E6.55113
G1 X5.386 Y4.692 E6.57055
G1 X5.117 Y5.208 E6.58993
G1 X4.779 Y5.684 E6.60938
G1 X4.38 Y6.108 E6.62877
G1 X3.926 Y6.474 E6.64819
G1 X3.427 Y6.774 E6.66759
G1 X2.891 Y7.004 E6.68702
G1 X2.329 Y7.158 E6.70643
G1 X1.491 Y7.241 E6.73448
G1 X-1.491 Y7.241 E6.83381
G1 X-2.072 Y7.201 E6.85321
G1 X-2.643 Y7.082 E6.87264
G1 X-3.192 Y6.886 E6.89206
G1 X-3.708 Y6.617 E6.91144
G1 X-4.184 Y6.279 E6.93089
G1 X-4.608 Y5.88 E6.95028
G1 X-4.974 Y5.426 E6.96971
G1 X-5.274 Y4.927 E6.9891
G1 X-5.504 Y4.391 E7.00853
G1 X-5.658 Y3.829 E7.02794
G1 X-5.741 Y2.991 E7.05599
G1 X-5.741 Y0.009 E7.15532
G1 X-5.701 Y-.572 E7.17472
G1 X-5.582 Y-1.143 E7.19415
G1 X-5.386 Y-1.692 E7.21357
G1 X-5.117 Y-2.208 E7.23295
G1 X-4.779 Y-2.684 E7.2524
G1 X-4.38 Y-3.108 E7.27179
G1 X-3.926 Y-3.474 E7.29122
G1 X-3.427 Y-3.774 E7.31061
G1 X-2.891 Y-4.004 E7.33004
G1 X-2.329 Y-4.158 E7.34945
G1 X-1.49 Y-4.241 E7.37753
G1 X1.492 Y-4.24 E7.47687
G0 F2625 X1.492 Y-3.74
G1 F900 X2.038 Y-3.7 E7.4951
G1 X2.572 Y-3.581 E7.51333
G1 X3.084 Y-3.385 E7.53159
G1 X3.561 Y-3.117 E7.54981
G1 X3.994 Y-2.782 E7.56805
G1 X4.374 Y-2.388 E7.58628
G1 X4.692 Y-1.943 E7.6045
G1 X4.942 Y-1.456 E7.62274
G1 X5.119 Y-.938 E7.64097
G1 X5.219 Y-.4 E7.6592
G1 X5.241 Y0.01 E7.67288
G1 X5.241 Y2.991 E7.77217
G1 X5.201 Y3.537 E7.79041
G1 X5.082 Y4.071 E7.80863
G1 X4.887 Y4.582 E7.82685
G1 X4.619 Y5.06 E7.84511
G1 X4.284 Y5.493 E7.86334
G1 X3.89 Y5.873 E7.88158
G1 X3.445 Y6.192 E7.89982
G1 X2.958 Y6.442 E7.91805
G1 X2.44 Y6.619 E7.93628
G1 X1.902 Y6.718 E7.95451
G1 X1.491 Y6.741 E7.96822
G1 X-1.491 Y6.741 E8.06755
G1 X-2.037 Y6.701 E8.08579
G1 X-2.571 Y6.582 E8.10401
G1 X-3.082 Y6.387 E8.12223
G1 X-3.56 Y6.119 E8.14048
G1 X-3.993 Y5.784 E8.15872
G1 X-4.373 Y5.39 E8.17695
G1 X-4.692 Y4.945 E8.19519
G1 X-4.942 Y4.458 E8.21343
G1 X-5.119 Y3.94 E8.23166
G1 X-5.218 Y3.402 E8.24988
G1 X-5.241 Y2.991 E8.26359
G1 X-5.241 Y0.009 E8.36293
G1 X-5.201 Y-.537 E8.38116
G1 X-5.082 Y-1.071 E8.39939
G1 X-4.887 Y-1.582 E8.4176
G1 X-4.619 Y-2.06 E8.43586
G1 X-4.284 Y-2.493 E8.4541
G1 X-3.89 Y-2.873 E8.47233
G1 X-3.445 Y-3.192 E8.49057
G1 X-2.958 Y-3.442 E8.5088
G1 X-2.44 Y-3.619 E8.52704
G1 X-1.902 Y-3.718 E8.54526
G1 X-1.49 Y-3.741 E8.559
G1 X1.492 Y-3.74 E8.65834
G0 F2625 X1.492 Y-3.24
G1 F900 X2 Y-3.2 E8.67531
G1 X2.495 Y-3.081 E8.69227
G1 X2.966 Y-2.886 E8.70925
G1 X3.401 Y-2.62 E8.72623
G1 X3.788 Y-2.289 E8.7432
G1 X4.119 Y-1.902 E8.76016
G1 X4.386 Y-1.467 E8.77716
G1 X4.581 Y-.997 E8.79411
G1 X4.7 Y-.502 E8.81107
G1 X4.741 Y0.01 E8.82818
G1 X4.741 Y2.991 E8.92748
G1 X4.701 Y3.499 E8.94445
G1 X4.582 Y3.994 E8.96141
G1 X4.387 Y4.465 E8.97839
G1 X4.121 Y4.9 E8.99537
G1 X3.791 Y5.287 E9.01232
G1 X3.404 Y5.619 E9.0293
G1 X2.969 Y5.885 E9.04628
G1 X2.499 Y6.081 E9.06325
G1 X2.004 Y6.2 E9.08021
G1 X1.491 Y6.241 E9.09735
G1 X-1.491 Y6.241 E9.19668
G1 X-1.999 Y6.201 E9.21365
G1 X-2.494 Y6.082 E9.23061
G1 X-2.965 Y5.887 E9.24759
G1 X-3.4 Y5.621 E9.26458
G1 X-3.787 Y5.291 E9.28152
G1 X-4.119 Y4.904 E9.2985
G1 X-4.385 Y4.469 E9.31549
G1 X-4.581 Y3.999 E9.33245
G1 X-4.7 Y3.504 E9.34941
G1 X-4.741 Y2.991 E9.36655
G1 X-4.741 Y0.009 E9.46588
G1 X-4.701 Y-.499 E9.48286
G1 X-4.582 Y-.994 E9.49982
G1 X-4.387 Y-1.465 E9.5168
G1 X-4.121 Y-1.9 E9.53378
G1 X-3.791 Y-2.287 E9.55072
G1 X-3.404 Y-2.619 E9.56771
G1 X-2.969 Y-2.885 E9.58469
G1 X-2.499 Y-3.081 E9.60165
G1 X-2.004 Y-3.2 E9.61861
G1 X-1.49 Y-3.241 E9.63579
G1 X1.492 Y-3.24 E9.73512
G1 F600 E8.23512
;MESH:
G0 F2625 X0.736 Y-.665
G0 X0.736 Y0.764
G0 X0.68 Y2.18
G0 X0.75 Y2.25
M104 S205
;TYPE:WALL-INNER
G1 F600 E9.73512
G1 F900 X-.75 Y2.25 E9.78509
G1 X-.75 Y0.75 E9.83505
G1 X0.75 Y0.75 E9.88502
G1 X0.75 Y2.25 E9.93498
G0 F2625 X1.25 Y2.75
;TYPE:WALL-OUTER
G1 F900 X-1.25 Y2.75 E10.01826
G1 X-1.25 Y0.25 E10.10153
G1 X1.25 Y0.25 E10.18481
G1 X1.25 Y2.75 E10.26809
G0 F2625 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E10.28541
G1 X-.26 Y1.24 E10.30273
G1 X0.26 Y1.24 E10.32005
G1 X0.26 Y1.76 E10.33737
G0 F2625 X0.25 Y1.75
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:34.971012
;LAYER:1
M140 S60
M221 S100 T0
M106 S51
;MESH:
G0 F6562.5 X0.75 Y2.25 Z0.565
;TYPE:WALL-INNER
G1 F666.7 X-.75 Y2.25 E10.35383
G1 X-.75 Y0.75 E10.37029
G1 X0.75 Y0.75 E10.38675
G1 X0.75 Y2.25 E10.40321
G0 F6562.5 X1.25 Y2.75
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E10.43064
G1 X-1.25 Y0.25 E10.45807
G1 X1.25 Y0.25 E10.4855
G1 X1.25 Y2.75 E10.51294
G0 F6562.5 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F800 X-.26 Y1.76 E10.51864
G1 X-.26 Y1.24 E10.52435
G1 X0.26 Y1.24 E10.53005
G1 X0.26 Y1.76 E10.53576
G0 F6562.5 X0.25 Y1.75
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:36.960496
;LAYER:2
M106 S102
;MESH:
G0 F10500 X0.75 Y2.25 Z0.705
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E10.55222
G1 X-.75 Y0.75 E10.56868
G1 X0.75 Y0.75 E10.58514
G1 X0.75 Y2.25 E10.6016
G0 F10500 X1.25 Y2.75
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E10.62903
G1 X-1.25 Y0.25 E10.65646
G1 X1.25 Y0.25 E10.68389
G1 X1.25 Y2.75 E10.71133
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E10.71703
G1 X-.26 Y1.24 E10.72274
G1 X0.26 Y1.24 E10.72844
G1 X0.26 Y1.76 E10.73415
G0 F10500 X0.25 Y1.75
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:38.914276
;LAYER:3
M106 S153
;MESH:
G0 X0.75 Y2.25 Z0.845
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E10.75061
G1 X-.75 Y0.75 E10.76707
G1 X0.75 Y0.75 E10.78353
G1 X0.75 Y2.25 E10.79999
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E10.82742
G1 X-1.25 Y0.25 E10.85485
G1 X1.25 Y0.25 E10.88228
G1 X1.25 Y2.75 E10.90971
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E10.91542
G1 X-.26 Y1.24 E10.92113
G1 X0.26 Y1.24 E10.92683
G1 X0.26 Y1.76 E10.93254
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:40.868056
;LAYER:4
M106 S204
;MESH:
G0 X0.75 Y2.25 Z0.985
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E10.949
G1 X-.75 Y0.75 E10.96546
G1 X0.75 Y0.75 E10.98192
G1 X0.75 Y2.25 E10.99837
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E11.02581
G1 X-1.25 Y0.25 E11.05324
G1 X1.25 Y0.25 E11.08067
G1 X1.25 Y2.75 E11.1081
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E11.11381
G1 X-.26 Y1.24 E11.11951
G1 X0.26 Y1.24 E11.12522
G1 X0.26 Y1.76 E11.13093
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:42.821837
;LAYER:5
M106 S255
;MESH:
G0 X0.75 Y2.25 Z1.125
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E11.14739
G1 X-.75 Y0.75 E11.16384
G1 X0.75 Y0.75 E11.1803
G1 X0.75 Y2.25 E11.19676
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E11.2242
G1 X-1.25 Y0.25 E11.25163
G1 X1.25 Y0.25 E11.27906
G1 X1.25 Y2.75 E11.30649
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E11.3122
G1 X-.26 Y1.24 E11.3179
G1 X0.26 Y1.24 E11.32361
G1 X0.26 Y1.76 E11.32931
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:44.775617
;LAYER:6
;MESH:
G0 X0.75 Y2.25 Z1.265
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E11.34577
G1 X-.75 Y0.75 E11.36223
G1 X0.75 Y0.75 E11.37869
G1 X0.75 Y2.25 E11.39515
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E11.42258
G1 X-1.25 Y0.25 E11.45002
G1 X1.25 Y0.25 E11.47745
G1 X1.25 Y2.75 E11.50488
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E11.51059
G1 X-.26 Y1.24 E11.51629
G1 X0.26 Y1.24 E11.522
G1 X0.26 Y1.76 E11.5277
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:46.729397
;LAYER:7
;MESH:
G0 X0.75 Y2.25 Z1.405
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E11.54416
G1 X-.75 Y0.75 E11.56062
G1 X0.75 Y0.75 E11.57708
G1 X0.75 Y2.25 E11.59354
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E11.62097
G1 X-1.25 Y0.25 E11.6484
G1 X1.25 Y0.25 E11.67584
G1 X1.25 Y2.75 E11.70327
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E11.70897
G1 X-.26 Y1.24 E11.71468
G1 X0.26 Y1.24 E11.72039
G1 X0.26 Y1.76 E11.72609
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:48.683177
;LAYER:8
;MESH:
G0 X0.75 Y2.25 Z1.545
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E11.74255
G1 X-.75 Y0.75 E11.75901
G1 X0.75 Y0.75 E11.77547
G1 X0.75 Y2.25 E11.79193
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E11.81936
G1 X-1.25 Y0.25 E11.84679
G1 X1.25 Y0.25 E11.87423
G1 X1.25 Y2.75 E11.90166
G0 F10500 X1 Y2.75
G0 X0.55 Y2.049
;TYPE:FILL
G1 F800 X-.55 Y0.948 E11.91873
G1 X-.638 Y0.86
G0 F10500 X0.55 Y0.948
G1 F800 X-.55 Y2.049 E11.93581
G1 X-.638 Y2.137
G0 F10500 X-.25 Y1.75
;MESH:NONMESH
G0 X0.68 Y2.18
G0 X0.75 Y2.25
;TIME_ELAPSED:50.857310
;LAYER:9
;MESH:
G0 X0.75 Y2.25 Z1.685
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E11.95227
G1 X-.75 Y0.75 E11.96873
G1 X0.75 Y0.75 E11.98519
G1 X0.75 Y2.25 E12.00165
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E12.02908
G1 X-1.25 Y0.25 E12.05651
G1 X1.25 Y0.25 E12.08395
G1 X1.25 Y2.75 E12.11138
G0 F10500 X1 Y2.75
G0 X0.55 Y2.049
;TYPE:FILL
G1 F800 X-.55 Y0.948 E12.12845
G1 X-.638 Y0.86
G1 F800 X-.55 Y2.049 E12.14553
G1 X-.638 Y2.137
;MESH:NONMESH
G0 X0.68 Y2.18
G0 X0.75 Y2.25
;TIME_ELAPSED:53.031442
;LAYER:10
;MESH:
G0 X0.75 Y2.25 Z1.825
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E12.16199
G1 X-.75 Y0.75 E12.17845
G1 X0.75 Y0.75 E12.19491
G1 X0.75 Y2.25 E12.21137
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E12.2388
G1 X-1.25 Y0.25 E12.26623
G1 X1.25 Y0.25 E12.29367
G1 X1.25 Y2.75 E12.3211
G0 F10500 X1 Y2.75
G0 X0.55 Y2.049
;TYPE:FILL
G1 F800 X-.55 Y0.948 E12.33817
G1 X-.638 Y0.86
G1 F800 X-.55 Y2.049 E12.35525
G1 X-.638 Y2.137
;MESH:NONMESH
G0 X0.68 Y2.18
G0 X0.75 Y2.25
;TIME_ELAPSED:55.205575
;LAYER:11
;MESH:
G0 X0.75 Y2.25 Z1.965
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E12.37171
G1 X-.75 Y0.75 E12.38817
G1 X0.75 Y0.75 E12.40463
G1 X0.75 Y2.25 E12.42109
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E12.44852
G1 X-1.25 Y0.25 E12.47595
G1 X1.25 Y0.25 E12.50339
G1 X1.25 Y2.75 E12.53082
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E12.53652
G1 X-.26 Y1.24 E12.54223
G1 X0.26 Y1.24 E12.54794
G1 X0.26 Y1.76 E12.55364
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:57.159355
;LAYER:12
;MESH:
G0 X0.75 Y2.25 Z2.105
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E12.5701
G1 X-.75 Y0.75 E12.58656
G1 X0.75 Y0.75 E12.60302
G1 X0.75 Y2.25 E12.61948
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E12.64691
G1 X-1.25 Y0.25 E12.67434
G1 X1.25 Y0.25 E12.70177
G1 X1.25 Y2.75 E12.72921
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E12.73491
G1 X-.26 Y1.24 E12.74062
G1 X0.26 Y1.24 E12.74632
G1 X0.26 Y1.76 E12.75203
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:59.113135
;LAYER:13
;MESH:
G0 X0.75 Y2.25 Z2.245
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E12.76849
G1 X-.75 Y0.75 E12.78495
G1 X0.75 Y0.75 E12.80141
G1 X0.75 Y2.25 E12.81787
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E12.8453
G1 X-1.25 Y0.25 E12.87273
G1 X1.25 Y0.25 E12.90016
G1 X1.25 Y2.75 E12.92759
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E12.9333
G1 X-.26 Y1.24 E12.93901
G1 X0.26 Y1.24 E12.94471
G1 X0.26 Y1.76 E12.95042
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:61.066915
;LAYER:14
;MESH:
G0 X0.75 Y2.25 Z2.385
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E12.96688
G1 X-.75 Y0.75 E12.98334
G1 X0.75 Y0.75 E12.9998
G1 X0.75 Y2.25 E13.01626
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E13.04369
G1 X-1.25 Y0.25 E13.07112
G1 X1.25 Y0.25 E13.09855
G1 X1.25 Y2.75 E13.12598
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E13.13169
G1 X-.26 Y1.24 E13.1374
G1 X0.26 Y1.24 E13.1431
G1 X0.26 Y1.76 E13.14881
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:63.020696
;LAYER:15
;MESH:
G0 X0.75 Y2.25 Z2.525
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E13.16527
G1 X-.75 Y0.75 E13.18173
G1 X0.75 Y0.75 E13.19818
G1 X0.75 Y2.25 E13.21464
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E13.24208
G1 X-1.25 Y0.25 E13.26951
G1 X1.25 Y0.25 E13.29694
G1 X1.25 Y2.75 E13.32437
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E13.33008
G1 X-.26 Y1.24 E13.33578
G1 X0.26 Y1.24 E13.34149
G1 X0.26 Y1.76 E13.3472
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:64.974476
;LAYER:16
;MESH:
G0 X0.75 Y2.25 Z2.665
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E13.36365
G1 X-.75 Y0.75 E13.38011
G1 X0.75 Y0.75 E13.39657
G1 X0.75 Y2.25 E13.41303
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E13.44046
G1 X-1.25 Y0.25 E13.4679
G1 X1.25 Y0.25 E13.49533
G1 X1.25 Y2.75 E13.52276
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E13.52847
G1 X-.26 Y1.24 E13.53417
G1 X0.26 Y1.24 E13.53988
G1 X0.26 Y1.76 E13.54558
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:66.928256
;LAYER:17
;MESH:
G0 X0.75 Y2.25 Z2.805
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E13.56204
G1 X-.75 Y0.75 E13.5785
G1 X0.75 Y0.75 E13.59496
G1 X0.75 Y2.25 E13.61142
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E13.63885
G1 X-1.25 Y0.25 E13.66629
G1 X1.25 Y0.25 E13.69372
G1 X1.25 Y2.75 E13.72115
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E13.72686
G1 X-.26 Y1.24 E13.73256
G1 X0.26 Y1.24 E13.73827
G1 X0.26 Y1.76 E13.74397
;MESH:NONMESH
G0 X0.75 Y2.25
;TIME_ELAPSED:68.882036
;LAYER:18
;MESH:
G0 X0.75 Y2.25 Z2.945
;TYPE:WALL-INNER
G1 F700 X-.75 Y2.25 E13.76043
G1 X-.75 Y0.75 E13.77689
G1 X0.75 Y0.75 E13.79335
G1 X0.75 Y2.25 E13.80981
;TYPE:WALL-OUTER
G1 F600 X-1.25 Y2.75 E13.83724
G1 X-1.25 Y0.25 E13.86467
G1 X1.25 Y0.25 E13.89211
G1 X1.25 Y2.75 E13.91954
G0 F10500 X1 Y2.75
G0 X0.68 Y2.18
G0 X0.26 Y1.76
;TYPE:SKIN
G1 F900 X-.26 Y1.76 E13.92524
G1 X-.26 Y1.24 E13.93095
G1 X0.26 Y1.24 E13.93666
G1 X0.26 Y1.76 E13.94236
;TIME_ELAPSED:70.788795
G1 F600 E12.44236
M140 S0
M107
M140 S45.0 ; start bed cooling
M104 S0 ; disable hotend
M107 ; disable fans
G91 ; relative positioning
G1 E-1 F300 ; filament retraction to release pressure
G1 Z20 E-5 X-20 Y-20 F3000 ; lift up and retract even more filament
G1 E6 ; re-prime extruder
M117 Cooling please wait ; progress indicator message on LCD
G1 Y0 F3000 ; move to cooling position
M190 R45.0 ; wait for bed to cool down to removal temp
G1 Y280 F3000 ; present finished print
M140 S45.0; keep temperature or cool downs
M77 ; stop GLCD timer
M84 ; disable steppers
M117 Print Complete. ; print complete message
M104 S0
;End of Gcode
Please attach Gcode files instead of posting contents. If you do attach small sections of Gcode, please use the Preformatted text tool (</>).
Iām 99% sure that your printer Machine Settings has āOrigin at Centerā checked (see below). It should not be checked for a TAZ 6.
You nailed it!
It was checked when it shouldnāt have been.
Thank you.
