So i recently got some 3mm iglide (iglidur) Tribo filament samples from IGUS recently and have been using it to test making linear bearings. It seems to be a very smooth material and seems excellent for this purpose. I will say that the white I180-PF is the one i liked and was easy to work with and would definitely buy a spool. The yellow J260 stuff was over extruding badly and was not sticking to itself very well and the parts were somewhat brittle. I did get one slider piece that seemed to come out ok, but it did have slight warping on the corners, but otherwise was fine.
http://www.thingiverse.com/make:239140
http://www.thingiverse.com/make:239145
You can order your 3mm samples here:
http://www.igus.com/wpck/15422/iglidur_TriboFilament?C=US&L=en
@i-t-w.com, since i get most of my filament spools from you i would like to request that you get some IGUS iglide I180-PF 3mm filament for me to order. Same goes for AO / Lulzbot themselves too.
