Using ABS. Hot end preheats at 230 then drops to 200 when Print starts, creating stringing on part… Tried changing temp in Settings>Slicing Settings>Printer and Filament>Temperature but still does it. What am I doing wrong here?
Make sure to re-export and re-load your .gcode into pronter. If you open your .gcode file in a text editor and look through the first couple dozen lines, you should -not- see an M104 S200 line, if you do, then you can delete that line and save the file and re-load it into pronter.
