linear bearing backlash, big X axis issues
I’ve got the same issue. The bearings were so sloppy I could easily twist the x carriage. I think is it just a poor choice of components. As for the noise, see this post TAZ 4 left & right Z motors get out of sync - it is NOT unrelated. Seems like a common issue. I think someone must know the secret to setting up the x rods, because as soon as I took mine out, I could not get them back together without the zaxis grinding and seizing. A whole lot of playing has got it to run mostly without noise and stopping.
I have replaced the IGUS with different bearings. We’ll see how they perform long term. I’ve only had the printer a few weeks, and not a lot of hours on it - maybe 30 - and those IGUS bearings were loose. They were probably that way the whole time - I probably just noticed after 30 hours of running. All the other axis are also loose as well. Its a systemic problem.
