@jebcom
Here’s how I remove parts from PEI:
I have a 0.063 PEI sheet from Zorro. I decided not to glue it down, so I use bulldog binder clips along the edges. I cut off a bit of each corner so the sheet fits between the Taz bed corner holders. I examine the sheet before putting it down. It’s cupped very slightly in one direction, so I put it on the bed so the center makes contact, and the binder clips along the edges pull the edges down.
If a print does not come off easily, I just remove the binder clips, pick up the PEI sheet, and flex it to break the adhesion with the part. That breaks enough of the part loose that I can then either pull it off, or get the clam knife blade under it to further remove it.
I think I may have gotten lucky by choosing this size of sheet. If it was thinner, I suspect I would have to use adhesive to hold it to the bed. If it was thicker, it would not be so flexible, and maybe this method would not work so well.
BTW, my PEI did have protective clear sheet on both sides. Both sides of my sheet seem to be equally glossy.
I’ve found PEI amber glossy finish to be the superior material. FYI, I’m printing ABS at 85F on the bed.
My findings resemble yours:
I’ve also been doing this over the past few weeks. And as you described there is a natural ‘bow’ to the sheet. So, if the bow goes face down on the glass and you pull the edges down it works excellent. However, if you do it the other way it will distort the bottom of your print.
Other observations:
The 0.063 amber glossy sheet I am using is the ‘amber glossy’ on both sides sheet. I also order the ‘natural finish’ and it DOES NOT WORK, fyi! Do not buy the ‘natural finish’ PEI. I absolutely could not get it to stick to that surface. Even though the surface appears ‘sanded’ in texture the high glossy finish is amazingly superior (contrary to what you would think).
Also, because of the heat diffusion on the 0.063 PEI amber sheet that is bulldog binder clipped to the top of my glass bed, I had to disconnect the print fan on the extruder, so that my small parts would not ‘pop up’ or ‘curl’ off the bed. Also, disconnecting the print fan dramatically improved the quality of all the prints on top of the 0.063 PEI amber sheet that is just clamped to the print bed. I now get all perfectly level prints which pop right off when you bend the sheet.
Another thing… if the bed is too hot:
When you flex the PEI sheet, be sure to look at the bow after you flex it. I have found that when my thick PEI sheet heats up the bow can reverse when you flex it while hot. So be sure that you’re placing the sheet bow down when you go to replace it. Also, applying the PEI sheet while the glass bed is still hot will cause the bow to increase. I have found for best results to let the bed cool to below 35F before reapplying the sheet.
And the edges of the bed:
On my printer, the best print seems to be in the center of the print bed. The edges of the 0.063 cool too quickly and I can get parts that pop off or have flaws and unevenness. I’m currently blaming this on the thickness of the PEI and the lack of an enclosure around the heat bed. The temperature of my house can fluctuate over night and this maybe the source of most of my 6+ hour print issues.
I have another 0.040 PEI amber sheet on the way. If the performance is better, I’ll let you know. My hope is that it will solve all my probs?
