Is it possible to print with PVA using the single extruder on the Taz6? Where do I find the material profile? There only seems to be information about using PVA on the dual extruders.
Well… there probably isn’t a PVA profile for the single extruder. Create your own using the filament manufacturer’s recommended temps… that’s really all you need to get started. Tweak the retraction so that the webbing goes away and check the over/underextrusion. The PVA profile on the dual extruder sounds like it may have other information about cooling and such.
Good luck! Share your profile when done.
