I had a rather lengthy print get to about the 50% mark and suddenly the printer threw an error (Using Octopi / Octopod- Error: Thermal Runaway, system stopped! Heater_ID: bed - Printer halted. kill() called!) and power cycled. It has happened from time to time… I took the print off the print bed and started over. The second print got to the exact same point and threw the same error (Thermal Runaway).
Instead of scraping it off the bed, I am hoping to edit the gcode to resume at the layer it aborted.
I have determined it was at layer 210 using calipers and math… I would like the edit the gcode to heat up and kick back off there.
Can anyone offer advice for which bits to remove from the front end of the gcode to avoid bed leveling, etc from crashing into the existing print?
Photo of failed print- https://imgur.com/YQdc9rv
Here is the gcode before layer 1:
;Generated by Cura LulzBot Edition GCodeWriter Version: 3.6.21
;FLAVOR:Marlin
;TIME:53064
;Filament used: 34.8372m, 0m
;Layer height: 0.3
;Generated with Cura_SteamEngine 3.6.21
T0
M82 ;absolute extrusion mode
; This profile is designed specifically for the LulzBot TAZ Pro with Dual Extruder Tool Head
M73 P0 ; clear GLCD progress bar
M75 ; start GLCD timer
M107 ; disable fans
G90 ; absolute positioning
M420 S0 ; disable previous leveling matrix
M140 S55.0 ; begin bed temping up
M104 S180 T0 ; soften filament
M104 S180 T1 ; soften filament
G28 ; home
M117 Heating... ; LCD status message
M109 R180 T0 ; wait for temp
M109 R180 T1 ; wait for temp
T0 ; select this extruder first
G92 E0 ; set extruder to zero
G1 E-10 F100 ; retract 10mm of filament on first extruder
G0 X50 F1000 ; move over to switch extruders
T1 ; switch extruders
G1 E-10 F100 ; retract 10mm of filament on second extruder
M104 S170 T0 ; set to wipe temp
M104 S170 T1 ; set to wipe temp
M106 ; turn on fans to speed cooling
T0 ; select first extruder for probing
G1 X-16.5 Y100 F2000 ; move above wiper pad
M117 Cooling... ; LCD status message
M109 R170 T0 ; wait for T0 to reach temp
M109 R170 T1 ; wait for T1 to reach temp
M107 ; turn off fan
G1 Z 1.0 ; push nozzle into wiper
G1 X -16.5 Y100 F1000 ; slow wipe
G1 X -16.5 Y90 F1000 ; slow wipe
G1 X -15.5 Y86 F2000 ; fast wipe
G1 X -17.5 Y80 F2000 ; fast wipe
G1 X -15.5 Y74 F2000 ; fast wipe
G1 X -17.5 Y70 F2000 ; fast wipe
G1 X -16.5 Y68 F1000 ; slow wipe
G1 X -16.5 Y60 F1000 ; slow wipe
G1 X -14.5 Y60 F1000 ; slow wipe
G1 X -14.5 Y46 F1000 ; slow wipe
G1 X -17.5 Y46 F1000 ; slow wipe
G1 X -17.5 Y60 F1000 ; slow wipe
G1 X -16.5 Y42 F1000 ; slow wipe
G1 X -15.5 Y40 F2000 ; fast wipe
G1 X -17.5 Y38 F2000 ; fast wipe
G1 X -15.5 Y36 F2000 ; fast wipe
G1 X -17.5 Y34 F2000 ; fast wipe
G1 X -16.5 Y30 F1000 ; slow wipe
G1 X -16.5 Y19 F1000 ; slow wipe
G1 X -16.5 Y19 Z20 F1000 ; raise extruder
M106 S255 ; turn on fan to blow away fuzzies
G4 S5 ; wait 5 seconds
M107 ; turn off fan
T1 ; switch to second extruder
G1 X296.5 Y100 F5000 ; move E2 above second wiper pad
G1 X 296.5 Y100 F1000 ; slow wipe
G1 X 296.5 Y90 F1000 ; slow wipe
G1 X 297.5 Y86 F2000 ; fast wipe
G1 X 295.5 Y80 F2000 ; fast wipe
G1 X 297.5 Y74 F2000 ; fast wipe
G1 X 295.5 Y70 F2000 ; fast wipe
G1 X 296.5 Y68 F1000 ; slow wipe
G1 X 296.5 Y60 F1000 ; slow wipe
G1 X 298 Y60 F1000 ; slow wipe
G1 X 298 Y46 F1000 ; slow wipe
G1 X 295 Y46 F1000 ; slow wipe
G1 X 295 Y60 F1000 ; slow wipe
G1 X 296.5 Y42 F1000 ; slow wipe
G1 X 297.5 Y40 F2000 ; fast wipe
G1 X 295.5 Y38 F2000 ; fast wipe
G1 X 297.5 Y36 F2000 ; fast wipe
G1 X 295.5 Y34 F2000 ; fast wipe
G1 X 297.5 Y30 F1000 ; slow wipe
G1 X 296.5 Y19 F1000 ; slow wipe
G1 X 296.5 Y19 Z20 F1000 ; raise extruder
M107 ; turn off fan
G0 X247 F1000 ; move over to switch extruders
T0 ; switch to first extruder
M109 R160 ; heat to probe temp
M204 S100 ; set accel for probing
G29 ; probe sequence (for auto-leveling)
M420 S1 ; enable leveling matrix
M204 S500 ; set accel back to normal
M104 S215 T0 ; set extruder temp
M104 S215 T1 ; set extruder temp
G1 X100 Y-29 Z0.5 F3000 ; move to open space
M400 ; clear buffer
M109 R215 T0 ; set extruder temp and wait
M109 R215 T1 ; set extruder temp and wait
M117 Purging... ; LCD status message
G1 E0 F100 ; undo retraction
G92 E-30 ; set extruder negative amount to purge
G1 E0 F100 ; purge XXmm of filament
G1 E-3 F200 ; purge retraction
G1 Z0.45 ; clear bed (barely)
G1 X100 Y10 F4000 ; move above bed to shear off filament
G4 S7 ; wait 7 seconds
M107 ; turn off fan
G1 X180 Y-29 Z0.45 F3000 ; move to open space
T1 ; set extruder
G1 E-4 F200 ; purge retraction
G1 Z0.35 ; clear bed (barely)
G1 X180 Y10 F4000 ; move above bed to shear off filament
T0 : set extruder
M190 R55.0 ; get bed temping up during first layer
G1 Z2 E0 F75 ; raise head and 0 extruder
M82 ; set to absolute mode
M400 ; clear buffer
M117 TAZ Printing... ; LCD status message
M221 S100 T0
M221 S100 T1
G92 E0
G1 F1200 E-1
;LAYER_COUNT:415
;LAYER:0
