I got the new Spare Textured flex sheet for my Workhorse. It’s not working as expected… The grip I get is really bad. My standard laminate PEI has a considerably stronger grip. I don’t know if I’m the problem or its the sheet itself.
Based on the pictures on the lulzbot site, the textured bed looks very similar to a BuildTak print surface. I have found that using a gluestick to apply glue to the build area helps a lot with bed adhesion. Every so often you will need to clean off the old glue with water and apply fresh glue. I use this on my buildtak beds all the time.
