Taz 6 12mm rod bushing replacement
I’m wanting to replace the 12mm rod bushings on my Taz 6. Is there any tricks to removal of the old bushings or installation of the new ones? I don’t want to damage anything in the process.
Having a press is key.
You’re the greatest!! Thank you.
I’ve got a press, so that will work out perfect. You can never have enough tools, hahaha.
Big c-clamps also work in a pinch. Block of wood and a mallet, not recommended.
Got them changed out without any issues. But one question, on the upper bushing holder, that has two bushings, is there any reason those bushings couldn’t have been pushed all the way thru one end? I wasn’t sure and didn’t want to risk it, so I was able to push one out from the middle surface, then pushed the second one out down the other end. Thank you for your help.
