I’ve just started using the TAZ 6 and for some reason, the X axis just doesn’t work. It moves fine on the Z and Y axes. I thought it might be a leveling problem, but I tried leveling it and that didn’t help. When I select auto home, the nozzle just… goes right down into the plate, and doesn’t stop unless I stop it.
When I try moving the X axis by turning the knob, the number on the display jumps to -022.0 and doesn’t change to any other number when I turn it.
There is also a message on the display that says “endstops hit: X” -what does this mean? Is it relevant to the problem?
Thanks so much!
