Hi,
Iḿ still having issues with my Taz Pro.
I’ve rebuilt the T0 tool of the dual extruder toolhead because
it turned out that the bearings on the hobb shaft had been destroyed.
now i’m having issues calibrating the printer.
Menu > Autohome
All axes home correctly.
Menu > Advanced settings > Tool offsets > Measure automatically
Then I do
Menu > Autohome
Menu > Advanced settings > Probe Z offset
I place a sheet of 80grams A4 paper on the bed.
T0 crashes into bed, I can see toolhead bending up.
After some adjustment. I get a -0.27mm Z offset.
Anything lower and the paper is stuck to the bed.
-0.27mm is the lowest that I can move the sheet of paper with some friction around,
and I can retract and re-insert the sheet between tool and bed.
Is this correct procedure?
Do I need thicker paper?
Isn’t -0.27mm a very low value if values of -1.10 to -1.25 are quoted ?
How do I create a test print to see is my settings are correct?
When I try to print the vernier on the provided usb stick,
Tool rubs against build surface.
I have to adjust z-offset to positive values?!
What am I doing wrong here??
