TAZ Slic3r profiles
http://devel.lulzbot.com/TAZ/3.1/software/2014Q1/slic3r/config/medium_ABS_no-support_pt35nzl_pt22layer/medium_ABS_no-support_pt35nzl_pt22layer.ini
http://devel.lulzbot.com/TAZ/3.1/software/2014Q1/slic3r/config/medium_ABS_auto-support_pt35noz_pt22layer/medium_ABS_auto-support_pt35nzl_pt22layer.ini
https://www.lulzbot.com/support/taz-slic3r-profiles
From the main website.
Here’s a couple of profiles that work decent for a .50 nozzle.
http://home.gci.net/~gghouck/Medium_ABS_no-support_pt50nzl_pt31layer.ini
http://home.gci.net/~gghouck/Medium_ABS_no-support_pt50nzl_pt22layer.ini
Appreciate the link but my problem with this is that Lulzbot is giving its customers a bad profile on their own website. It seems like it is a very minor fix to change the fill to 20-25%. I think it is bad for the company to not fix this.
We provide the Slic3r profiles as a starting point for our customers. Please keep in mind that most of our users will tweak each slicing profile to suit their particular model, as there are always ways to improve your print, model by model, slice by slice.
The infill density is a variable that can be changed print by print. A higher infill density will help with models with small structures. The medium profile is set to be used as a profile that will work for almost all models and all users.
The two profiles you linked do not have any hot end or bed temperatures specified in the configuration file. Make sure it’s imported correctly. Your temperature settings under the filament tab will read “0” if you imported successfully. If you are using the Fine ABS profile, we have different temperatures specified in that particular profile for improved bridging/overhangs to help balance out the thinner layers and increased layer time.
So you are saying that the 50% infill in the medium profile on the Lulzbot is intentional?
What they’re saying is that the 50% infill is adjustable…
I personally don’t find 20-25% to be optimum, wouldn’t really call that a “fix”.
Can lulzbot supply (or anyone else) a profile for dual extruder, with a GOOD profile for PVA support material?
I’ve been following these instructions to load a new profile:
“To view the contents of each profile simply click on them. Your browser should display the contents. To save the profile right click on the profile you would like and select “Save as”. Once saved to a memorable location, load the configuration file in Slic3r by selecting File > Import Config.”
After choosing import config I select the ini. file and click open and Slic3r crashes every time.
Any ideas as to what is going on?
Thank you.
Also, I’ve tried it on multiple version of slic3r the latest of which is: slic3r-mswin-x86-1-1-7-stable (1)
Try right-clicking the link to save-as then load that file the same way.
Can you post a link to the file you saved? Perhaps something is getting added or taken away.
Also, Windows tries to “help” by adding .txt to the file extension at times. Make sure the file extension is .ini. You can turn on file extension displaying by changing a setting in Windows at Control Panel (change from category view to view by small icons) > Folder options > Hide file extensions for known types.
Mac OsX tries to “help” you as well.
Right click on the file -> Informations -> Name&Suffix and just remove the .txt that worked for me.
Also in Slic3r the submenu Import Config under File is now called Load config, isn’t it? I’m very new to this and this just confused me a litte :smiley:
I am having what I think is a windows issue. I click save as, confirm its ini as the file extension. when I double check in explore, the profile is listed that way but when I go to load the profile, it shows now profiles listed. I think windows is still ‘classifying’ it as a text file even though it clearly has the ini file extension. I have the same issue with cura profiles and gcode files. anyone else have the issue? is there a way to fix that? thanks!
Winwoods hides the extension of known filetypes so my bet is you’re looking a file named config.ini.txt or the like. Make sure you configure winwoods to show extension of known filetypes and you won’t be fooled anymore.
thank you for responding, the file type is classified as text so I think that is my issue (I am viewing in full details). I think that is my issue.
yep that is the issue, it is calling it .ini.txt, i had to change some permissions to make it stop that. thank you!!!
I had the same issue and couldnt figure out why the test parts came out botched. I fixed the working directory setting in Slicer Manager and now the prints are flawless. Yay
