We have some new Slic3r profiles available for those wanting a starting point in Slic3r. There are 3 main profiles: fast, medium and fine. Each of the three have two options, either with support turned on, and set for autosupport, or support turned off and set with the standard 45 degree overhang threshold.
They can be found here: https://www.lulzbot.com/support/taz-slic3r-profiles
To view the contents of each profile simply click on them. Your browser should display the contents. To save the profile right click on the profile you would like and select “Save as”. Once saved to a memorable location, load the configuration file in Slic3r by selecting File > Import Config.
