Thanks for the reply… My offset is at -1.10 right now… The real issue for me is that I have to adjust the z-offset after each autolevel. I wish the script didnt run every time before each print and saved older leveling data… It’s also a major issue that the left side of my bed is slightly higher than the right. On the skirt that prints the left is too squished while the right side is barely staying attached. I have not found a reliable way to not adjust things before each print which is really annoying.
you can save your print settings by going to to the console and typing M500 (enter) after getting everything where you want it…I am having the same issue though. Calibrated everything, changed Esteps and z-offset. First layer is fine, but then after that it drags through the print. I am really frustrated!
