This is the same problem I have with the Seeed SO_Arm100 kit. I tried various settings on the stepper motor gauge, but haven’t found anything to work, yet. I am not going to start printing the whole arm until I can get the motor to fit into the gauge correctly.
Seeed provided STL files with Ender and Prusa labels, but neither would fit when printed on either of my Taz6’s. One Taz6 has an SE 0.50mm tool head and the other has 0.5mm tool head I got off eBay for 1.75 filament.
I haven’t had a chance to work with this lately.
I sent a message to Seeed asking for the CAD files because editing STL files is such a pain in the ass. I haven’t heard anything back from them.
When I get a chance to play with it again, I will try the Horizontal Expansion setting, because I do not want to try scaling parts and cause other issues in trying to get the arm to fit together.
The message I sent to seeed on January 17th
is below:
seeed SO-ARM100 Pro Robot Arm STL Files
I purchased a kit to build a robotic arm from seeed. The kit uses downloaded STL files so one can print the arm parts. They provide STL files for Prusa and Ender printers. They also provide a guide to be printed to determine how accurate the prints will be.
The guide is a rectangular block with outsets at each end. It is designed to accept the STS3215 stepper motors used in the robot. The idea is to ensure that the stepper motors fit tight in the arm parts.
I printed the guide on two Taz 6’s, one with a SE 0.50mm toolhead and one with a made to order replacement toolhead designed for 1.75mm filament. This toolhead has the same 0.50mm nozzle as the original toolhead. (LulzBot TAZ 6 1.75mm Single Extruder Tool Head .5mm Nozzle, plug and play | eBay)
I used Cura 4.10.13 Experimental to slice the guides in High Detail for both printers. The 1.75 printer was using Tough PLA from Inland and the SE printer used Polymaker PolyLite PLA.
The prints from both printers are too tight to get the stepper motors inserted. The specs on the motors say 24.7mm by 35mm. Using a digital caliper, I measure the printed guide as having 24.49mm and 34.68mm inside measurements. When I load the STL file into my CAD program, the long dimension seems to be .1mm shorter than the stepper motor specification (35mm). And, narrow dimension is exactly 27mm, which is the motor specification. These dimensions leave absolutely no room for filament contraction upon printing.
Has anyone tried printing this robot arm on a Lulzbot Taz 6 3D printer?
Are the CAD drawing files available for download so I can adjust them for a LulzBot printer?
Thank you for your assistance with this.
