What high temp filament to use with TAZ 6
I have a stock TAZ 6 which I usually use with PLA, but occasionally I need to use something that will not melt or get soft at temperatures found inside a car.
I have used Polymaker PC-Max up to now. But my stock is just about out and it appears to be no longer available.
So, what can I use that the lulzbot store has?
What settings should I use on the printer for this new filament?
I see that polymaker has PolyMax-PC but the description in the store says it needs a certain print head to be able to be used.
I also see an ASA version of the polylite. The store says nothing about a special head. Would this work for me? Again, with what settings?
BTW, I am using Cura version 3.6.20
What sort of “high-temp” are you talking about? PETG prints easy, just be sure you don’t print directly on glass.
But for higher-temp and from Lulzbot’s store, colorFabb has their co-polyester stuff. colorFabb High Temp
Also, nylon blends: Polymaker PolyMide CoPA
Consider updating CuraLE, lulzbot is fairly good at keeping what’s in their store as profiles in their current slicer.
Well, I left it pretty a bit undefined on purpose.
I am looking for a pretty rigid material: about as rigid (high modulus of elasticity) as the PLA I usually print with.
It needs to not soften (the way the polylite PLA does) at 100c.. or at least be as good as possible.
The PC-Max material seems to do well on both counts.
I will look into the other materials you suggested as possibilities. My previous IMPRESSION of them was they they were not as high temp-capable and were less “rigid”. But I need real data on that, not an impression.
I am concerned about updating to the newest Cura LE because it will need to update the firmware and I am not sure I can go backward to the old one if it is not acceptable.
-Tony
Firmware can be upgraded or downgraded at will. This is an open-source machine in every way.
Just record your e-steps and z offset.
