Hey guys, so my problem started yesterday afternoon, my printer started making a weird noise, so i came to check, the build plate was all the way in front, not moving as usual. So i stopped the print to check. So i moved the build plate to the middle and tried to home it, but all it did was move a little bit in front.
I contacted customer support who diagnosed it as perhaps a bad switch or a bad cable chain after some tests.
Here’s the thing, so i took a multimeter, disconnected the connectors from the switch, and manually clicked it, to test if there’s a connection. It worked, so yay, its not the switch.
I then connected the wires back, and took out the connecter to the board, did the same thing at the wire ends, and it works too! (beep on my multimeter when i click the switch).
So, ok, neither the cable nor the switch are at fault, so leaving it unplugged, i ran cura and entered in M119, turns out the z-min is still being triggered, which prevents the bed from moving in the negative direction.
Any suggestions as to what i can try next? I’m really hoping not to send it back in for repair as shipping from here would be burning a hole in my wallet…
