I tried using some acetone on a folded paper towel, rubbing my print while the towel is wet repeatedly. It does smooth the surface but leaves it a little lumpy. Sanding does not seem to work much either as it kinda gums up (before applying acetone). There must be a better way!
thanks nopick… very cool. I will try that as a final step. In the meantime, I rubbed acetone over the entire print using smooth chemical disposable gloves twice. I then followed it by rubbing with a paper towel soaked in acetone… the surface became very smooth.
I also had some cracks in my print. I fixed them by making an ABS slurry, 50% acetone + 50% ABS leftovers. I painted them into the gaps, some 1/8" open, several times and let it set before polishing. This also worked excellent on the seams where i welded parts together.
