I’m printing (on a mini) a vice grip that needs to have soft jaws while maintaining enough pressure to keep the piece in place. I’ve no experience in anything but PLA, and hoping someone can recommend a filament material for the application.
I’m building a vice grip out of PLA. But the objects I’m trying to hold onto with the vice will be of irregular shape (not squared off against the jaws). So, in order to retain a tight grip on the part, I need the jaws to have a sponge-like surface… something that will conform to the object, then spring back after the object is removed, ready for another to be placed.
Imagine trying to hold a sphere in a vice grip so you could drill a hole in it. A vice grip with typical metal jaws (PLA in my case) would loose grip as the sphere is drilled into (the sphere is not strong enough to withstand significant pressure). So I need the jaws to have a spongy pad to conform to the spherical object to keep it held securely.
The only filaments I’m aware of that might fit the bill are ninja flex and the lay-fomm. I’ve used neither. As you point out, the ninja flex will require a new extruder, and I’d like to know if it would suit the application before I make that investment.
I’m thinking the fomm filament (linked above) would suit the application well, but I have not been able to find any information on printing via the mini with that type of filament, and looking for input if anyone has experience or knowledge about that filament usage on a mini.
I don’t think the foam stuff would have much grab. The foam products I have around wouldn’t work well for that, though I’ve never printed any foam filament. I suspect TPU based filament like Ninjaflex would work fine though. I’ve only used it for a few things, but it seemed to have good friction when pressed against something else.
I have tested the very same thing.
I found Semiflex (the one AO sells) to be the best solution.
Best grip I got with squared infill 40%. I have it in the vise that I can look through the squares when i look from the top on the vice.
