Any suggestions on how to fix basic bridging problems with my prints?
What problems are you having? We don’t have ESP…
Pictures, sample STL, and filament type would help.
They key is to help the filament cool and solidify as soon as possible. Here are some generic suggestions:
- Increase extrusion cooling usually helps
- Extrusion temp as low as possible
Keep in mind each of these may affect the print in different ways.
Spanning 5-8mm should be pretty easy… if the span is larger, then you’ll really have to tweak your settings.
