My screen looks nothing like the manual, and I cannot find a place to change any of the many parameters described in the manual. Some examples:
- There is no overhang view. Only Solid, Xray, Layer.
- If I go to either Settings or Preferences, I find a “settings visibility” menu, in which all of the parameters I have read about are displayed, but only with a checkbox controlling “visibility” of the parameter. There is no value, nor any ability to change the parameter. Whether I set it to “visible” or “not visible”, it is not visible anywhere. I see no menu to change or even see the value of any of these parameters. I have been around all the menus about 100 times over a period of 5-6 hours. I cannot find any new menus.
For example, just looking at the first few items on the “settings visibility menu”, I see for example “initial layer height”. I am told in the manual that this should be defaulted to 0.425mm, but I cannot find what it is set to, nor can I change it. I only can check a box next to “initial layer height”, and checking this box does nothing as far as I can see. Same is true for about 100 other parameters on this list.
I do see elsewhere a few parameters. For example, I see a menu for skirt/brim/raft/none. I see a few other isolated boxes I can control. But it is basically about 1% of the parameters I can view and change. The rest are a mystery.
