Can we use this on the Mini 1?
Or does the Lulzbot 3.6.20 edition support the Settings Guide Plug In and how does one install this Settings Guide?
Thanks
Thanks
The printer is open source, so you should be able to use Cura 4.1. But, be prepared to open a can of worms trying to get it to work. LulzBot doesn’t support it and to my knowledge, there is no centralized support for it.
There are a couple of ways you can check for the plugin you need in 3.6.20. First you can check the Plugins section at the top of your screen for installed plugins.
You can also check with Ultimake’rs website and forums for the information.
