Hi,
Took the plunge with 3D printing with the TAZ 6 and purchased on behalf of my company.
The filament choices are pretty amazing. Tried to search here and a couple other places but did not find what I was looking for described below.
Does anyone know of a spreadsheet that lays out all the main properties/parameters/limitations/advantages of filaments in one place in order to make it easier to make informed choices on what filaments are best for which applications? Seems like it would be great if there was a head to head comparison in no particular order:
Processing Temp
Bed Temp
Bed Preparation Needed
Post processing heat resistance
Post processing technique: Glue/sand/paint
Bridge Capability
Durometer/stiffness/flexibility
Clarity
Glossy or dull finish
Wear resistance–functionality is stress environments
COF/slipperiness
UV stability
Tendency to warp/shrink–enclosure recommended & temperature of enclosure environment
Chemical to dissolve with
What print head is needed for best processing
Odor(s) if any
Found lots of information but just not all in once place so the optimal filament could be selected based on certain compromises for the application.
Thanks
