Has anyone tried ninjaflex in this extruder yet? In more of a direct drive setup?
The cyclops requires a lot more pressure to push filament through. I don’t think flexible filaments would do too well.
Plus bith sides would need to be flexible filament. You can’t really blend filament types with this hot end as they share a chamber.
I have the same set up with a Cyclops hot end pluse the dual Bond Tech extruders. I also have used your firmware on the taz printer and that has resolved a lot of my issues except when I try to extrude with ext1 it makes a sound like it want to move but it doesnt. I know the extruder is good because I have run both of extruders before with the Marlin firmware installed. Please help and thank you.
Can you post your config.h file so we can take a look. It sounds like a misconfiguration issue.
Thanks for the quick reply @mhackney I just found out that it was a lose cable and that fixed it. Do you have a patreon because you have saved me a lot of time with everything and i would like to pay you for all the great info you have supplied. You are truly a 3d printing God.
Great that it was something simple!
Thanks for the kind words! Just pay it forward some day and my work will be complete.
Cheers,
Michael
Most of my issues are resolved. But when I am using Simplify3d and hit home Y it moved the bed all the way to the front.
Repetier-Firmware-2016-05-18.zip (433 KB)
Also are the endstops suppose to work ?
End stops work. Can you post a photo of homed position so we see what you mean.
I can’t help on S3D, I threw it away.
I made a video of my issue and put it on vimeo. Let me know any thoughts on why it does this when I try and home the Y axis. https://vimeo.com/167213343
I figured it out. I just needed to change the #define INVERT_Y_DIR 0 from 0 to 1.
I will try to print a test cube and see how it goes. Thanks for all the info and help.
I was wanting to know if @mhackney could post your Kissslicer settings? Thanks again
I was wondering if there was any updates to this mount over the last year?
I’m just about a year late finding out about the Cyclops hotend with QR extruder setup for my Taz 5 setup. I was hoping to get an update on the complete setup for conversion. So anyone can hit the ground running.
Hot End
Extruder
Is anyone using this in Repetier & Slic3r
Not really, it’s been working fine so I haven’t had a need to tweak it. Not sure if/why you would need an update. Let me know.
cheers,
Michael
