I have something I would like to try, but what I’ve tried so far doesn’t work (no big surprise really).
If you look at the attached, I have tried:
G1 X0 Y250
M226
and the head moves to X0 Y250 but no pause, it just moves right back and starts printing again.
Has anyone tried doing this in gcode? Using KISSlicer BTW.
Also, assuming I do get M226 to work, will sending another M226 resume printing? Is it like a toggle?
It looks like M226 may not be supported in Marlin. There are MANY g- and m-codes and not all of them are implemented in any firmware. It looks like Marlin may treat this as an M0 - which is a stop - turns off motors, heaters, etc. Not what you want to do.
If it worked as a pause you would use M24 to restart.
What are you trying to do? It looks like you might want to use M25.
Just playing around really. I would like to try to Pause, Move to X,Y, do a task, then resume.
Imagine an arm, like a piston connecting rod (not really, but will work for this example).
I want to print an arm with a pocket, pause, insert something into the pocket, then resume printing to encapsulate the item in the arm.
I’ll try M25, but SD Pause seemed to me like it for printing from SD card.
I have used G4 S5 (pause 5 seconds) and know that works but it isn’t exactly the behavior you are looking for. You could make the pause very long but then you’d have to wait.
