My heater resistor is dead once again. It is the second time in the last two months.
It wouldn’t be much of a trouble but we have different standards in my country so I cannot find the one that will suit the heater block. Either it is too small or to weak or something else…
Luckily I still have one spare left, but I cannot order resistor from lulzbot every time it goes off. The shipping is just not worth it.
Any ideas?
thanks
edit:
Also I am very careful when insulating the resistor wires from the heater block, so It couldn’t have short circuited
thank you for the data.
It seem that I cannot find that particular heat resistor nowhere around my place. I’ve tried everywhere.
And the shipping from the link you gave would be 120$ for a 1$ heat resistor
My bot is TAZ3.1 with Budaschnozzle 2.0 and firmware is Marlin 1.0.0
I would like some advice on getting this piece for my hotend: http://e3d-online.com/Electrical/Components/Heater-Cartridge-12v
Is it possible? Could it be more useful for me who cannot get his hands on the standard resistor?
And most important, what adjustments would I need to make?
I want to share some results of analyzing our TAZ3 with oscilloscope. Since we are trying to find more permanent solution for heating, I called up an electrician-
We were trying to get a grasp on what’s going on while the heater is on.
We got, of course, different values for heat start, closing up on desired temperature, and maintaining the desired temp
Here is an image of the graphs overlapped. It’s made by hand but it shows those impulses when the heat command is set
So the only difference is in milliseconds duration of the impulse
What concerns me is that I’ve been told that the heater resistor uses much more power then it is designed for. Something like 12W even, and it has the label of 7W
It probably happens because it does not transfer the heat well, in my case. So naturally, the thermistor requires more power of it, in order to reach the level
I am trying to find a solution for better heat transfer. There are 2 options so far
-heater cartridge
-cementing the resistor
