I have a Hexagon Hot End. Re-flash was successful for higher temps.
The Hexagon is about 20mm shorter than Buda 2.0 and can’t crank down Z stop low enough to get to the print bed. With the Z stop all the way down I’m still about 10mm away from the bed. Anyone encounter this or can think of a fix? If I put something under the bed to raise it, then the bed level adjustments won’t work.
This mount is 10mm shorter, from the top of the extruder mounting surface to the bottom edge of the french cleat. How well did the Hex mate to the extruder?
Are there Hexagon mounts for the TAZ 4 dual extruder? Also wondering if there are fan mounts we can print out in case I want to print w/ PLA (unless the Hexagon doesn’t require a fan)?
Hi, I see that the Hexa on reprap discount is equipped for 12V power supply, with it’s heater cartridge and fan.
Is it possible to find ones for 24V since my TAZ3 has that Voltage power supply?
I notice in the first post that re-flashing is needed if installing hexa
Are there any instructions for the procedure?
Also, are there any more things I need to know before putting it on?
Like what is the thermistor limit for temperature (but I guess that comes with the hotend package)
And if it’s not a secret where are you guys getting it from? Is it Reprap discount-
they are selling it with 12v heater cartridge only
