I printed a test 10mm cube using Cura 15.02 on my newly completed Kittaz. I used the Lulzbot Cura fine HIPS profile, but changed the bed temp to 110 which seems to work well for adhesion directly on PET and fan set to 40% instead of 35. The issue is that the corners and edges on the side of the print that the fan is facing form nice crisp edges and corners, but the corners and edges on the side of the cube opposite the fan are rounded.
Also, another issue I am having is that while the start gcode is added, the two commands to extrude 3mm of filament don’t seem to occur. On this small 10mm cube, no filament extruded until almost halfway through the print of the first layer.
Any thoughts on this would be appreciated.
Scott
