I had some issues installing Cura LE 3.6.37 on Ubuntu 22.04 using the deb file on the download page. After finding nothing on Google, I looked into it. Turns out the developers are depending on an old package that is no longer available in Ubuntu 22.04. Luckily, there’s a replacement that seems to work. You just have to change the dependency in the deb file. Here’s how you do it:
- Download the deb file for Debian 11 on the download https://gitlab.com/lulzbot3d/cura-le/release/-/raw/master/cura-lulzbot-3.6.37-deb11-Linux.deb
- Navigate to the file in a terminal and unpack the deb file:
ar x cura-lulzbot-3.6.37-deb11-Linux.deb. You will see a few files:control.tar.xz,data.tar.xzanddebian-binary. - Update the dependencies in control.tar.xz/control:
vim control.tar.xzselect control, and changelibssl1.1tolibssl3. Save the file. - Repack the deb file:
ar rcs cura-fixed.deb debian-binary control.tar.xz data.tar.xz - Install the deb file:
sudo apt install ./cura-fixed.deb - Run cura-le:
cura-lulzbot
I assume this will work on other distros with this problem, but YMMV.
