I use the Lulzbot edition of Cura. I ran it with the console and got these errors:
<<< [13:15:28] //action:notification Leveling Print Bed…
<<< [13:15:28] ok N60 P14 B13
<<< [13:15:28] ok P14 B13
<<< [13:15:30] echo:busy: processing
<<< [13:15:36] Error:!! STOP called because of BLTouch error - restart with M999
<<< [13:15:36] echo:Writing UI settings to SPI Flash (offset -32404)…DONE
<<< [13:15:36] EEPROM backed up to SPI Flash
<<< [13:15:36] Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
<<< [13:15:36] //action:notification STOPPED.
<<< [13:15:36] //action:notification Preheating…
<<< [13:15:37] Preheating
<<< [13:15:40] Error:!! STOP called because of BLTouch error - restart with M999
<<< [13:15:40] echo:Writing UI settings to SPI Flash (offset -32404)…DONE
<<< [13:15:40] EEPROM backed up to SPI Flash
<<< [13:15:44] Error:!! STOP called because of BLTouch error - restart with M999
<<< [13:15:44] echo:Writing UI settings to SPI Flash (offset -32404)…DONE
<<< [13:15:44] EEPROM backed up to SPI Flash
<<< [13:15:46] Error:!! STOP called because of BLTouch error - restart with M999
<<< [13:15:46] echo:Writing UI settings to SPI Flash (offset -32404)…DONE
<<< [13:15:46] EEPROM backed up to SPI Flash
<<< [13:15:46] //action:notification Probing Failed
<<< [13:15:47] Error:Probing Failed
<<< [13:15:47] X:88.00 Y:52.00 Z:15.00 E:-12.00 Count X:8775 Y:5200 Z:7500
<<< [13:15:47] ok N61 P15 B12
<<< [13:15:47] ok N62 P15 B13
<<< [13:15:47] echo:Invalid mesh.
<<< [13:15:47] Error:Failed to enable Bed Leveling
<<< [13:15:47] echo:Bed Leveling OFF
<<< [13:15:47] echo:Fade Height OFF
<<< [13:15:47] ok N63 P15 B14
<<< [13:15:47] ok N64 P15 B14
<<< [13:15:47] ok T:156.36 /235.00 B:63.56 /0.00 @:0 B@:0
<<< [13:15:48] ok N65 P15 B12
<<< [13:15:48] ok P15 B13
<<< [13:15:48] ok N66 P15 B14
<<< [13:15:48] //action:notification Final Heating… Please Wait.
<<< [13:15:48] ok N67 P15 B15
<<< [13:15:48] Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
<<< [13:15:48] //action:notification STOPPED.
<<< [13:15:48] echo:Writing UI settings to SPI Flash (offset -32404)…DONE
<<< [13:15:48] EEPROM backed up to SPI Flash
<<< [13:15:48] ok N68 P15 B12
<<< [13:15:48] T:155.62 /235.00 B:63.33 /0.00 @:0 B@:0 W:?
<<< [13:15:49] T:155.58 /235.00 B:63.17 /0.00 @:127 B@:0 W:?
<<< [13:15:50] T:155.85 /235.00 B:63.12 /0.00 @:127 B@:0 W:?
<<< [13:15:50] echo:busy: processing
<<< [13:15:51] T:156.69 /235.00 B:62.89 /0.00 @:127 B@:0 W:?
