so, i recently fixed my older taz 5 (several plastic parts broke) the first print i exported using cura exported with the proper bed dimensions, but every file after that has exported as if the bed size was 10 by 10 by 10 mm-i’m very lost, i’ve tried to fiddle with the code as much as i can, but i do not know much about code. what do i do to make sure the dimensions stay correct when exporting it to gcode and saving it on an sd drive? the stl files are the right size, but when i upload the gcode back into cura to check, it says 10 by 10 by 10, and every print is messed up…thanks!
Please tell us more about your slicer. What version? What OS is it installed on?
Please attempt to slice a small object like a 15x15x15mm cube and upload both the .stl file and the .gcode file.
The more details you give us, the better chance we have of helping you.
